Puttin' her away
  • Thread starter Thread starter notny41
  • Start date Start date Nov 15, 2004
1 of 2 Next Last
notny41
204
Minnesota
Nov 15, 2004
  • Nov 15, 2004
Let's hear some tips for winter storage.
Is it worth putting up on jack stands to give the springs longer life?
Otherwise just add Stabil to the tank and fill it up with gas and park it?
RGS0907
429
New Jersey
Nov 16, 2004
  • Nov 16, 2004
I've owned my GT500 since 1975. I never did much at all to 'prepare' it & it always worked fine. More recently, I add Stabil to the fuel (I learned from my father's boat) and I switched to Mobil-1 so that the initial start up in March isn't too abusive. The car has been doing fine.
mfp4073
387
Hells Ditch, FL
Nov 16, 2004
  • Nov 16, 2004
HEHE, you know the funny thing....down here winter contains the driving months! No rain or heat!
67GTA-FB429
777
Tri-Cities, Wa
Nov 16, 2004
  • Nov 16, 2004
WOW. How about those hurricanes though? And not the Miami ones.
67GTA-FB429
777
Tri-Cities, Wa
Nov 16, 2004
  • Nov 16, 2004
Put a trickle charger on it.
If you are not going to start it at all or drive it around on nice days, get the fuel out of the carb, so that the internals don't gum up (happened to me once, was not pretty when the throttle stuck).
Make sure your antifreeze is ready.
O
Ozsum2
695
  • Nov 16, 2004
There was a thread a few days ago where we covered everything on this subject. Might want to check it out.
T
The Dan
319
Orange County, CA
Nov 16, 2004
  • Nov 16, 2004
The best things I've ever learned about storing a car is:
1. Sta-Bil in the gas tank.
2. Run all the gas out of the carb., then fill the float bowls with WD-40. Makes a great presrvative for the seals, and won't gum anything up.
3. Put the car away with frsh oil, and change it again when it comes out.
Now that I've been in CA for 11 years I need not heed any of these!
Max Power
1,774
St Paul
Nov 16, 2004
  • Nov 16, 2004
I always put Stabil in it and run it long enough so that the fuel in the carb has plenty of Stabil in it. Honestly, filling the carb with WD-40 sounds like more work than rebuilding it.
With Stabil in there, it won't gum up.
Jacking the car up isn't to save the springs. Cars are built to sit on their springs 24/7/365. There isn't a car built that wasn't designed to always sit on their springs!
Jacking it up is so the tires don't flat spot. I have never bothered and I never have any problems.
O
Ozsum2
695
  • Nov 16, 2004
I've always heard that WD-40 was perfumed kerosene. Any thoughts?
T
The Dan
319
Orange County, CA
Nov 16, 2004
#10
  • Nov 16, 2004
  • #10
Quote: Honestly, filling the carb with WD-40 sounds like more work than rebuilding it.
Huh??? It takes about 2 minutes to take out the srews on the side of the float bowls and spray the WD in, then put the screws back in. I'm not seeing that as being the same as a rebuild
T
The Dan
319
Orange County, CA
Nov 16, 2004
#11
  • Nov 16, 2004
  • #11
Most penetrants and lubes are petrolium based, so it may not be too far from the truth, all I know is that it works fine, and does well to preserve the carb when sitting for a few months.
O
Ozsum2
695
#12
  • Nov 16, 2004
  • #12
Well, it may have been a slight exaggeration from Max. Depending on the length of storage, the carb may go dry and in that case, a rebuild may be required anyway. Depending on what carb he or you have, you may have to pull off the top as in my 2100. There is a small vent, but I don't think the straw would go in.
Max Power
1,774
St Paul
Nov 16, 2004
#13
  • Nov 16, 2004
  • #13
Of course it was a slight exaggeration, but Oz is right, it would be a pain in the ass on some styles of carbs, especially considering it's unneccessary.
I used to drain the carbs in my motorcycles every winter, and after a while, the residue in the float bowls would dry up, crack off and prevent the needles from seating, so I quit doing that. Stabil works just fine.
2nd Mustang
2,488
Southern California
Nov 16, 2004
#14
  • Nov 16, 2004
  • #14
A little off topic, but I've tried using WD40 on my pistols, but found that they really "gum up" the moving parts really bad in cold weather. I've since switched to Lucas gun oil (ironically, got samples at the drag races) which seems to work better on my pistols.
R
Rumble
21
Ontario, Canada
Nov 16, 2004
#15
  • Nov 16, 2004
  • #15
Don't jack up your car, the suspension doesn't like to be unloaded and the original reason for it--flat spotting the tires--isn't a concern with modern radial tires.
Fuel stabilizer is a must, I use the no-name stuff from CarQuest. Stabil is good too but damn it has a really annoying bottle.
69Rcode_Mach1
1,473
Salt Lake City, Utah
Nov 16, 2004
#16
  • Nov 16, 2004
  • #16
Hey guys im preparing for winter too, but i start the car up and let it warm up atleast 3 days a week during the winter, is that okay or do i still need to get some of this sta-bil stuff and what is it ive never heard of it?
O
Ozsum2
695
#17
  • Nov 17, 2004
  • #17
3 days a week is almost like daily driving it. You should do nothing, unless the tank will last longer than 3 months. Then you need fuel stabilizer.
O
Ozsum2
695
#18
  • Nov 17, 2004
  • #18
Try a little powdered graphite during cold weather. Nothing to gum up and it lubes pretty well.
draco_1967
42
#19
  • Nov 17, 2004
  • #19
For long term storage, coat it(lightly) with silicone spray lubricant. It will prevent any rust(gun oil won't do that). When you take it out, spray some more one and wipe off.
O
Ozsum2
695
#20
  • Nov 17, 2004
  • #20
I didn't take that he was long term storaging his gun. Since he said cold weather, I took it that he was using them in cold weather, and the graphite isn't effected by the cold.
1 of 2 Next Last
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
