PVC Valve
sage2k
645
Baton Rouge, LA
Guys how do i get to the pvc valve, i cant see it or reach behind the intake theres like 50 wires running back there
also passenger side by firewall is a cylinder shaped connecter with two small rubber hoses one running behind intake and one going to firewall, what is this thing?
The PCV is directly below the rear intake runner. You can barely see it, just put on some gloves and feel around.
The cylinder thing is the canister purge solenoid I think. It vents the gas tank vapor into your intake.
:stupid:
behind the intake, there is a large wrapped bundle of wires that goes directly above the pcv valve, i think they are mostly for the injectors. find the 11/32" vacuum hose coming out of the back of the intake and follow that.
The guys are right on.
You can push the harness over the PCV valve toward the firewall a little to get the valve out. Make sure the valve seats and stays seated upon reinstallation (that harness can kinda want to sideload the valve).
Good luck.
