PYTHON ALARM QUESTIONS???
91whiteponygt
61
bought car with python alarm installed already, wires in drivers door that go to the door lock switch were cut so i splive them back together, now switch works but clickers wont control locks, with hitting the unlock buttom or lock the lights flash and something under the dash clicks but the locks dont actually move ???
Did you find any relays for the locks? That sounds horrible - the installer should have cut the wires at the door lock connectors at the top of the driver kick panel.
The relays allow for the existing wires to be connected with the relay at rest but switches power to the actuator when you hit the key fob. Unless they disabled the interior door switches during the install (by design), there should be a relay or 451M module somewhere.
If you had factory keyless, relays arent needed but you sure wouldnt cut wires in the driver door during the install.
Weird.
