  • SN95 4.6L Mustang Tech
quad shock ?
  • Thread starter Thread starter 4.6boy
  • Start date Start date May 10, 2009
4.6boy
187
  • May 10, 2009
both my quads are leaking oil is it normal for them to be blown after only 74000 miles?
squeak93
2,315
391
164
Joplin, Missouri
May 11, 2009
  • May 11, 2009
Prob not normal but possible. They are cheap to replace anyway.
Flghtmstr1
572
Springfield, PA
May 11, 2009
  • May 11, 2009
Just get some good LCAs and ditch the quad shocks. They were a stupid idea in the first place.
mustang50v8
548
847 Chicago Burbs
May 11, 2009
  • May 11, 2009
for sure
the extra heavy duty ones from maximum motorsports would be your best bet.
StangYellow
1,052
May 12, 2009
  • May 12, 2009
I just installed the MM adjustable lowers.....and left the quads in. I dont need them?
squeak93
2,315
391
164
Joplin, Missouri
May 12, 2009
  • May 12, 2009
You do not 'Need" them with aftermarket lca's. But if they are not in the way of anything and in good working order, no need in pulling them. They do serve a good purpose with the factory suspension set up as it is very prone to flex under a load.... Don't want that going on now do we?
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
May 12, 2009
  • May 12, 2009
Adding LCA's doesnt' guarantee elimination of wheel hop. The only thing that does are quad shocks. I'd leave them on.
Flghtmstr1
572
Springfield, PA
May 13, 2009
  • May 13, 2009
Why leave them on if they're no longer functioning? The real question is whether he should pony up for new ones, or just ditch them.
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
May 13, 2009
  • May 13, 2009
By "leave the on", I mean keep them as part of the system. If they're shot, by all means replace them.
20BlackGT02
63
#10
  • May 14, 2009
  • #10
Mine started to leak at about 74,000 miles too. I replaced mine with Bilsteins and man did they make a difference. It seems like I can take corners a lot faster without feeling the car sway or I think it's called body roll, maybe. Well worth it. They compliment my Bilstein shocks very well. And they only take about 60 minutes a side to replace if you are a novice like me.
blackfang
1,290
Richmond, Va
May 16, 2009
#11
  • May 16, 2009
  • #11
I'd replace them. Believe it or not they serve a purpose as the Mustangs suspension you have isn't the greatest design. Leaving them in will help, unless you go with a TA/PHB/LCA setup.
Suspension Quad shocks
  • keel
  • May 20, 2026
Fox 5.0 Mustang Tech Sep 2, 2026
AeroCoupe
Clutch pedal to Quadrant lag
  • Potomus Pete
  • Aug 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
M
Bent Rear Spring Perches
  • Miozu
  • Aug 18, 2025
SN95 4.6L Mustang Tech Sep 8, 2025
PSKSAM2
P
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
J
2001 coolant issue
  • jr273
  • Jan 24, 2026
  • The Welcome Wagon
The Welcome Wagon Jan 24, 2026
