Quadrant spacers...?
  • Thread starter Thread starter Kid wita 5oh
  • Start date Start date May 17, 2009
Kid wita 5oh
I'm definitely not in the original hole
1,410
150
93
Saugus, MA
May 17, 2009
  • May 17, 2009
my upr quadrant didnt come with any spacers.
anyone know how much it needs to be spaced out to line up properly?
thanks
Rick 91GT
Mustang Master
95
99
PA
May 18, 2009
  • May 18, 2009
You shouldn't need any spacers to get it to line up....
Kid wita 5oh
1,410
150
93
Saugus, MA
May 18, 2009
  • May 18, 2009
let me re-phrase...to keep it lined up(the path of the cable to the firewall), its seems as though it could be able to slide to the left...or does the cale keep it in place?
thanks
Darkwriter77
Resident Ranting Negative Nancy
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
May 18, 2009
  • May 18, 2009
Cable keeps it in place just fine. No problems with my UPR quad for almost 5 years now.
Kid wita 5oh
1,410
150
93
Saugus, MA
May 18, 2009
  • May 18, 2009
cool thanks!
i ran one years ago on my last car but i couldnt remember how it was
f8tlfiveo
My wife likes my spool and blow-off valve.
Aug 8, 2007
1,585
102
64
Lancaster, PA
May 20, 2009
  • May 20, 2009
if you do not use spacers the quaddant will move side to side. i took mine out that someone had installed previously and it had worn a new groove in the quadrant Posted via Mobile Device
V
v8only
2,378
22
49
May 20, 2009
  • May 20, 2009
No it won't.
The only way it would do this is if your cable adj wasn't tight enough.
I've installed probably 15-20 quadrants over my fox years...never spaced them out once, never had one issue.
f8tlfiveo
Aug 8, 2007
1,585
102
64
Lancaster, PA
May 21, 2009
  • May 21, 2009
i dont know but mine definatly had a groove worn in it.. and there were no spacers installed.
93 LX
3,081
Norwalk, CA.
May 21, 2009
  • May 21, 2009
Just installed my MM quad and it has several washers. I think it was 4 inside and 2 outside of the quad.
Darkwriter77
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
May 21, 2009
#10
  • May 21, 2009
  • #10
MM's quad does address this specifically by design, but honestly I think it's a little bit overkill. As stated, having the clutch cable too loose where it can move around and shift about will make it such that your quad can shift aside and thus you'll wind up with the funky wear pattern that can rub your cable raw. However, I've done 4 or so quad swaps on a few Foxes and never once has quad alignment become an issue at any point because neither I nor those whom I've helped install them on their cars like to keep their cable so loose that it becomes an issue. While MM does make and sell awesome stuff, I think in a case like this they tend to over-engineer things to where they're "fixing" issues that aren't really all that common or preventing problems that rarely (if ever) arise.
You could always spring for a MM quad if you're really that worried about it and just want the extra peace of mind, but unless you're actually experiencing alignment issues with your cable, then I would think it's completely unnecessary. As long as you're using a good (FORD!) cable and you have the tension properly adjusted, you shouldn't be having any issues.
kpack5982
Yeah, it was pretty stiff, but eventually a buddy
Jul 13, 2005
325
Granger, IA
May 22, 2009
#11
  • May 22, 2009
  • #11
I marked the place where the quadrant sat once I had it tightened, then loosened the cable up and put washers in, but only to ease my mind a little.
HISSIN50
34
129
May 22, 2009
#12
  • May 22, 2009
  • #12
If the pegs are slightly out of whack or the quadrant has hole(s) that are too big, the quadrant can move or get cockeyed, thus allowing cable chafing. I won't install a quadrant without using spacers.
The OEM quadrant is located, and MM locates theirs via spacers.
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
Interior and Upholstery HVAC Mode selector vacuum switch issue.
  • parish99
  • Jul 3, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
KAWMAN2
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Hammer shifter problems
  • 387lx
  • Apr 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 11, 2026
General karthief
P
Vacuum
  • ProTechAutoServices
  • Aug 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2026
