  • SN95 4.6L Mustang Tech
Quality differences in K-Members?
  • Thread starter Thread starter reeber
  • Start date Start date May 19, 2006
reeber
574
26
38
Berlin, NJ
May 19, 2006
  • May 19, 2006
Is there really that big of a difference between K-Members? Maximum motorsports is the one I was going to buy for about $600... You can get UPR's version for about $200. What could make them that much different????
J
JOHNS01GT
209
Vermont
May 19, 2006
  • May 19, 2006
Strength, weight, materials, fit, finish, name. This is what pops into my head, I don't know of the exact differences but Maximum Motorsports is the best and UPR is known to be cheap. Most parts, can't comment on each companies individual K-members because I have neither!!!
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
May 19, 2006
  • May 19, 2006
MM > *
Also, tubular K + front end collision = yer dead
GT12207
86
California
May 19, 2006
  • May 19, 2006
MM's k-member is the strongest, but probably heaviest aftermarket k-member.
What are tubular k-members and a-arms good for anyways? less weight? that's it? If that's the case then you're better off moving the battery to the trunk and getting a rear seat delete
tomustang
Psychotic Member
3,434
McLean Hospital
May 19, 2006
  • May 19, 2006
GT12207 said:
What are tubular k-members and a-arms good for anyways?less weight? that's it? If that's the case then you're better off moving the battery to the trunk and getting a rear seat delete
To better place the front suspension, different mounting points, strengthen weak areas yada yada yada
Think about all the extra cable you will have moving the battery
01Steeda
732
Baton Rouge, LA
May 19, 2006
  • May 19, 2006
Yeah they seriously help handling. I have an AJE K-member and I had a huge improvement in my steering response form the K member. plus if your putting LT's on they give you more room to work with.
propellerhead
1,541
"but what's with the but shots?"
May 19, 2006
  • May 19, 2006
Has anyone looked into how aftermarket k-members do in front end collisions? Isn't the stock k-member part of the structure that forces the engine and transmission down during a collision? If so, does the aftermarket k-member do the same?
01Steeda
732
Baton Rouge, LA
May 19, 2006
  • May 19, 2006
my plan is to not get into one
all joking aside, most of the mods we do to our cars are not saftey oriented, the K-member may be a bit more to the unsafe side, but drag racing or autocross is inherintly (sp?) dangerous. I dont know how it effects the designed crash behavoir, but it wouldnt change my mind anyway.
reeber
574
26
38
Berlin, NJ
May 20, 2006
  • May 20, 2006
I have long tubes, no rear seats, and have no plans to move the battery. My big question, which still hasn't been fully answered, is:
Do you think it is worth putting the extra money into a more expensive (MM) K-Member? I am also buying the new control arms and coil over kit with Bilsteins. Should I just get the whole MM kit? I heard they are the best fit, but I am just afraid I am paying a lot just because of the name. I did buy the MM chrome CC plates and they ROCK, so I wanted to stick with what I am pleased with... I don't know... I am sure I'll still go with all MM products, because I refuse to buy cheap stuff, but if someone can talk be out of the expensive K-Member, than please do... SAVE ME SOME MONEY!
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
May 20, 2006
#10
  • May 20, 2006
  • #10
I think you should buy MM, I do not think you are paying for the name. You are paying for superior design and quality.
tomustang
Psychotic Member
3,434
McLean Hospital
May 20, 2006
#11
  • May 20, 2006
  • #11
oops (Edited) and reused for space
Yes get the whole MM kit, you could either opt for the offset wheel placement but you'll have to cut some fenderwell out
like i said before go MM or don't, URP, PA, all the others are NOT recommended for street/road/auto-x, they are just looking for lighter weight and tell you it's strong as chit, and of course, whatever is stronger will break thru something weaker. How would you like for a tubed K member to say high to your body when it rip right thru sheet metal? not saying it's plausable but anything could happen
tomustang
Psychotic Member
3,434
McLean Hospital
May 20, 2006
#12
  • May 20, 2006
  • #12
I've looked into it
and found nothing, testing K-members for collisions test is very expensive and no manufacturer will do it
The stock Member has crumble points in the structure which bend on impact, aftermkt K's don't because they are looking for lightweight-durable enough, or strengthening, racing needs. Depending on the year, not sure about 94-98's but 99+s are designed to drop the engine from the K-member in a front end collision. So there is 2 main points where the stock K-member is different in a safty standpoint
Your best suggestion (and i advice this) is to contact your insurance company and find out if aftermkt K-members are 'ok' to change out with them
tomustang
Psychotic Member
3,434
McLean Hospital
May 20, 2006
#13
  • May 20, 2006
  • #13
oh and Eric, whatever you do DO NOT buy the granatelli k member because it looks like the MM one
hotmustang331
2,967
Bastrop,TX
May 20, 2006
#14
  • May 20, 2006
  • #14
If im not mistaken, the MM one is HEAVY....like not much lighter at all. I went with PA racing. Its very nice, but I think they gave me the wrong one....my darn motor mount holes wernt even close and that mild steel is HARD to grind out lol. Otherwise it seems ok....oh and my LTs were hitting the motor mount too, so I tied down the motor and stopped that.
I dropped like 62#s with the K/A arms/coilovers.
I say get the PA racing K/A arms and buy the MM coilovers. My QA1 coilovers transmit ALOT of vibrations on big bumps.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
May 20, 2006
#15
  • May 20, 2006
  • #15
it all depends on what you are doing with the car. if you want to make it into just a drag racer, then by all means use the UPR one. you will have maximum weight savings off the front end of the car. they are best to be used straight line, i wouldnt want to corner with one.
however if you plan to corner carve, then you would want to use the MM one, or the griggs one. you sacrafice the weight loss, but get better suspension mountion and location. like in the MM one, it moves the wheels forward about .75" thus allowing you to run more positive caster. you tend to want a stronger unit with a road racer to better handle the stronger lateral g-forces.
tomustang
Psychotic Member
3,434
McLean Hospital
May 20, 2006
#16
  • May 20, 2006
  • #16
well the avg Ford K weighs 50lbs, give or take a lb, the MM one is 36lbs
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
Any 1 find any decent blackfriday sales for Foxbody or car stuff?
  • rednotch
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 19, 2025
rednotch
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
