Quarter Window removal, Molding, Effects brackets?
  • Thread starter Thread starter Nightstalker5.0
  • Start date Start date Mar 30, 2004
1 of 2 Next Last
N
Nightstalker5.0
10
  • Mar 30, 2004
How do you remove the quarter windows and molding?, How do you remove the molding that is attached to the body that goes around the door seem, Does anyone have a set of ground effects brackets, new or where i can find them? Let me know Justin
87' GT
R
rdksek844
300
Port St. Lucie, FL
Mar 30, 2004
  • Mar 30, 2004
I also curious about the quarter windows but to remove the trim around the door all you do is remove the screw near where the mirror part of the door closes and pull down on the trim piece gently. It should slip right off, there are about 4 or 5 sheet metal clips holding it on. Thats it.
04sleeper
2,674
14
89
Dallas, TX
Mar 30, 2004
  • Mar 30, 2004
In order to remove the Quarter windows you must first remove the inside rear interior panels. Then you will see small nuts around the edge of the window. (the window has studs coming out of it). Remove all the nuts. Then take a thin screwdriver or coathanger to push through the black glue. I used a thin peice of fishing wire and just kept moving it back and forth in a sawing motion and worked it all the way around the window to seperate the glue from the car and the window. I had a friend outside of the car with the other end of the wire while I was inside. You could use a coat hanger but it requires more effort. (Bigger diameter wire) Don't try to pry the window with a screwdriver or it will break!
Hope that helps.
R
rdksek844
300
Port St. Lucie, FL
Mar 30, 2004
  • Mar 30, 2004
Thats a preety good description. Thanks.
04sleeper
2,674
14
89
Dallas, TX
Mar 30, 2004
  • Mar 30, 2004
No problem
R
rdksek844
300
Port St. Lucie, FL
Mar 30, 2004
  • Mar 30, 2004
89sleeper, how much does your car weigh? I have more mods except for the intake than you and you got me by .5 and 4mph. Im just curious because if your car is stock weight than I'm really in dire need of an intake.
04sleeper
2,674
14
89
Dallas, TX
Mar 30, 2004
  • Mar 30, 2004
I weighed my car that night at Moroso Motorsports Park in WPB and it weighed 2980 without me and 3180 with me. I was running skinnies and no spare tire with about 1/4 tank of gas.
R
rdksek844
300
Port St. Lucie, FL
Mar 30, 2004
  • Mar 30, 2004
Yeah I ran my best there the first night it opened for the season. I havent weighed mine yet so I dont know what stock weight is, is yours stripped down at all?
04sleeper
2,674
14
89
Dallas, TX
Mar 30, 2004
  • Mar 30, 2004
Not really. I still have a full interior but I do have a stock raise fiberglass hood and a tubular K-member and A-arms and coil over front's. Also I have a factory manual rack from a 79-81 Mustang. I think the Intake helps me. I also tried 2 sets of headers.....MAC 1 1/2" Equal Length Shorties and FRPP 1 5/8" Ceramic Shorties. I lost power with both so I actually grinded down the weld on the inside of my stock headers and put them back on. I will put the FRPP's back on when I get my new shortblock and some heads. You are in PSL.....We should hook up some time.
R
rdksek844
300
Port St. Lucie, FL
Mar 30, 2004
#10
  • Mar 30, 2004
  • #10
Yeah, when's your next time at the track gonna be?
04sleeper
2,674
14
89
Dallas, TX
Mar 30, 2004
#11
  • Mar 30, 2004
  • #11
I'll PM you
R
rdksek844
300
Port St. Lucie, FL
Mar 30, 2004
#12
  • Mar 30, 2004
  • #12
ok
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Mar 30, 2004
#13
  • Mar 30, 2004
  • #13
I might be doing this soon. I hate the pitted rubber arround the windows. Ugg, it ruins the car. Everything is replacable except the quarter glass window moldings, which are attached to the windows, and they don't make new stuff even if you manage to get the rubber off the glass. {If I am wrong, please let me know}
I am going to try a rubber primer to fill in the cracks and black trim paint, I have the stuff, just scared to give it a try. Original worn looks better than halfassed fixed.
N
Nightstalker5.0
10
#14
  • Mar 30, 2004
  • #14
Thanks for your help guys, day in day out work on the stang, Im 16 and im sick of seeing all the **** jobs, I don't care how long it takes but im doing it all right, once, Quarter windows are next in line so thanks for the help.
PS: anyone know if they sell a Ground effects bracket kit? they're all brittle, and have to be replaced, i've attempted to make that out of galvanized but the 1/8 lip is tough to make round on a bender. Let me know
87'GTstang
1,025
#15
  • Mar 30, 2004
  • #15
Not sure as to the effectiveness to them, but they do make plastic moldings that fit over top the exiting ones and "hide the unsightly and weathered factory moldings perfectly", or as they state.......
These seem to be the cheapest, but there are others:
Quarter window moldings
Anyone tried them?
C
CPB00GT
531
Florida
Mar 30, 2004
#16
  • Mar 30, 2004
  • #16
Steeda has them in there newer catalog for 99 dollars I think. I also saw them somewhere else, I believe it was Dugan for about the same price. I am thinking about giving them a try. I repainted my door trim, now the 1/4 moldings really look like crap.
bgjohnson
963
johnston,iowa
Mar 30, 2004
#17
  • Mar 30, 2004
  • #17
damn I need to do mine too, I hear those moldings stick out and start peeling off, so for me to clarify you pop or uncrew the plastic molding on the inside of the rear quarter window, then you unscrew the the nuts on the inside, then get the window off but separating the glue from the body. OK now do you need to put new adhesive back on the window after you paint it?
R
rdksek844
300
Port St. Lucie, FL
Mar 31, 2004
#18
  • Mar 31, 2004
  • #18
Actually 5.0 resto has remade ones for 500.00 plus core for new replacements.
Asha'man
1,909
Denver
Mar 31, 2004
#19
  • Mar 31, 2004
  • #19
I believe Dugan Racing has the same core exchange program for $300.
Ash
J
j.speed
384
Meriden, CT
Mar 31, 2004
#20
  • Mar 31, 2004
  • #20
Does anyone know if these plastic moldings would fit an 89 Mustang Notchback? Or are they just for Hatchbacks?
Thanks,
1 of 2 Next Last
D
Rust on Window Belt
  • DuluthFoxbody
  • Wednesday at 8:36 AM
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Wednesday at 3:32 PM
DuluthFoxbody
D
Rear quarter window regulator
  • BADAZZOMBIE08
  • Mar 29, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Mar 29, 2026
BADAZZOMBIE08
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
Rust under side window weatherstrip
  • swe13
  • Jun 5, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jun 5, 2025
swe13
  • dan50
  • Jul 18, 2026
dan50
