  • 1994 - 1995 Specific Tech
qucik question
  • Thread starter Thread starter ISUrb33
  • Start date Start date Feb 2, 2007
I
ISUrb33
30
Longview TX
Feb 2, 2007
  • Feb 2, 2007
My car has been running fine but all of a sudden the car will die when im driving down the road, sometimes it will stay off and sometimes it will start back up while the car is still rolling wqithout me turning the key. I am confused and not sure what the problem is. I was thinking maybe there is a short in the fuel regulator? I honestly have no clue what it could be. I thought once a car died it was dead until you turn it back on but since it will restart itself I dont know what it is. Any help would be very usefull. Thanks
drakesdad
961
Oregon OHIO
Feb 2, 2007
  • Feb 2, 2007
If it's a stick and the key is still turned to the run position..not start.....it would be like "bump" starting......that was a trick a lot of us used with sticks when the battery was dead etc......push the car with the key on run and dump the clutch with the car in gear..........have you checked the car for codes......?
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Feb 2, 2007
  • Feb 2, 2007
I would do like he said, check for codes first, then clean your maf/iat, then do a cylinder balance test followed by a fuel pressure and vacuum test.
Scott
mustang6tee8
375
College Station, TX
Feb 2, 2007
  • Feb 2, 2007
mine had been doing that once every few days up until 2 weeks ago, i know exactly how you feel- it's annoying and confusing as hell.
check the voltage on your ignition control module (under the MAF), clean out all of the connections under the hood, make sure the ground wire from the battery to the engine is clean and working good. dont waste money by buying a new coil (like i did) or a new ICM (like i did).
dont buy something unless it's broken...
...and that is the most broken rule here on :SNSign:
HISSIN50
34
129
Feb 2, 2007
  • Feb 2, 2007
Wade, sorry to hear you're still fighting that bug.
ISU, also let us know how long it shuts-off for? A split second, a second, 2 seconds, etc?
Good luck.
69clark
731
Ravena, NY
Feb 2, 2007
  • Feb 2, 2007
My guess.... PIP
If thats what it is than you should get a code for it.
I
ISUrb33
30
Longview TX
Feb 3, 2007
  • Feb 3, 2007
I am sorry, i forgot to mention. This problem is happening in my daily driver which is a bone stock mustang GT , full exhaust, and is an automatic. im not sure if that makes a difference or not.
xr8d302
I bought a 27" monitor to compensate for my lack o
Apr 29, 2004
1,113
Medicine Hat, AB
Feb 3, 2007
  • Feb 3, 2007
69clark said:
My guess.... PIP
Tom got to it first, but those sound like the symptoms of a bad pickup..
The fact that it's bone stock won't matter here, it's not a hard repair, just a dizzy rebuild.
Run codes?
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
I
98 Mustang GT dying
  • ItsMason
  • May 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 25, 2026
lenzgt
L
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
