Questio about 351w--->408
kosovo37
Hi i, thinking in take some modifications to my 351w
I have
Trickflow camshaft hydraulic roller tapped stage 2 542/563 lift
Flat top pistons with 0.60 bore ( Keith Black)
Crane rocker arms with 1.6 ratio
Maley Valves with 1.600 Exhaust and 1.94 Intake
Ported piston heads ( this one are from a 302 H.O)
Trickflow springs upgrade kit
Edelbrock air gap intake Manifold
BBk shorty headers
Msd Distribuitor
Msd digital-6 plus
Holley 750 carb with vacuum advance, double pumper
So the question is, what do i need to convert it in a 408
Thanks
Yep...
Stock 351 CI:
A 351 utilizes a 4.00" bore, 3.50" stroke, 5.956" rod, and a 1.772" compression height piston.
351 CI Strokers:
A 393 utilizes a 4.030" bore, 3.85" stroke. 5.956" rod, and 1.608" compression height piston. It uses a 2.300" crank journal. The 5.956" rod is a stock 351 Windsor rod. The 1.608 piston is the same as the 302. The 393 is typically known to save money as compared to the 408. A 393 can also be created with a 6.200" rod, with a different compression height piston.
A 408 utilizes a 4.030" bore (but you have .040" pistons, so a 410?), 4.00" stroke, 6.250" rod and a 1.250" compression height piston. It can use a 2.100" crank journal, which has less friction.
The 393 moves 3,850 fps at 6,000 RPM.
The 408 moves 4,000 fps at 6,000 RPM.
