Question about fitment
I'm not sure if I'm saying this right, but if your heads were shaved, would you have problems sealing the lower to the heads? I got the car used and I cant understand why the new lower is not sealing to the heads. What is it called when the deck of the heads have been shaved?
i think it the term is "planed". maybe your heads are warped? if the heads somehow got warped, then they are no longer perfectly flat. then you would have vaccuum issues when intalling then on a new lower that is flat. i would say take them to a machine shop and ask them to see if they are warped.
I would do this as well if I was you.
Do I really have to do this or can I check them at home, cause I dont want to take off my heads and go through the trouble of putting them back on if I'm not changing them. Not to mention having to buy all the gaskets. They're stock iron E7's so how would they be warped?
Well since I dont have any cooling problems or smoke out of the tailpipes, that means the block side of the heads is not warped right? That means that I can just use a straight edge on the intake side of the heads to see if they're warped? Correct me if I'm wrong. I don't know that much about heads.
As long as the oil is not mixing with the coolant pretty much means the head is sealed to the block properly(not warped). As far why the lower is not sealing to the heads is weird. Are the gasket staying put or are they moving on you when you place the lower down? You can use the straight edge to make sure they are "true" and not warped but I have never heard of that side of the head being warped(here the lower intake sits).
maybe the lower is warped. that could be a possibility. every head from the factory is never perfectly straight. there always a few tho off. but nothing to be worried about. easiest way is to use the straight edge and feeler gauge method
oh, a PP intake. ya, i heared a few people having problems with them.
where do you think the intake is leaking from the sides (attaches to the heads) or the front and back (the block)????
if its from the front and back, what are you using? the cork ends or silicon? or both?
you could try staking the lower where it attaches to the block so that the silicon has something better to stick to. just use a puch and put a bunch of pit marks in 2 rows across.
maybe that could be your cause
sorry about that, staking a ****ty word to use.
use a center punch and dimple about 2 rows all the way across the lower manifold ends where the rubber ends attach to. but this time just use a bead of silicon. this way the silicon has something to stick to.
