Question about front 5 lug conversion
  • Thread starter Thread starter Shadow 1
  • Start date Start date Mar 13, 2007
1 of 2 Next Last
Shadow 1
33
Gresham, OR
Mar 13, 2007
  • Mar 13, 2007
I have a 85 hatchback and I was thinking about doing a conversion on it when I rebuild it. I think I got the rear figured out but what about the fronts, I heard I can put on spindles from a 94-95 stang but I'm unsure what all's needed. Anyone got any idea's?
Fett
766
  • Mar 13, 2007
Yes, spindles from an SN95 will work, but you will need a spacer for the ball joint.
Do a search for "5 conversion", you should find a ton of info.
P
PJB
131
Rotterdam, NY
Mar 13, 2007
  • Mar 13, 2007
You will also need '87+ struts since your car is an '85. The '94+ spindles dont bolt up to pre-'87 struts.
twolo4u2c2
5 Year Member
Apr 10, 2003
330
reading, PA
Mar 13, 2007
  • Mar 13, 2007
go here ........is all the info youll need!
http://svo73mm.cjb.net/
Shadow 1
33
Gresham, OR
Mar 13, 2007
  • Mar 13, 2007
Thanks for all the info guys, I'll be sure to check them out!
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Mar 13, 2007
  • Mar 13, 2007
The front is a breeze. You will also need to turn your tie rods out to get them to hook to the spindles. They take about 17-18 turns outward, this way you can get it to the alignment shop like the next day! You will also need the 94-98 calipers, brackets, rotors, and rubber flex hoses. You can also use 99-04 PBR's, they will work too. You will need to grind a small spot on the spindle for the PBR's...you will see where they rub when you try to bolt them down. Mine also required a union on the passenger side to get it to thread in the hard line.
Shadow 1
33
Gresham, OR
Mar 13, 2007
  • Mar 13, 2007
Does the brake booster and stuff need to be changed out as well?
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Mar 14, 2007
  • Mar 14, 2007
Do not use 94-98 front calipers as they are heavy and single piston and are not much of an upgrade over stock Fox calipers, at the very least go with the 99-04s
f4fntm
88
Olympia, WA
Mar 14, 2007
  • Mar 14, 2007
Congrats on your excellent taste in cars (four-eye).
The fronts are easy. The rears are the tricky thing. Master cylinder and proportioning valve replacement/revision is required, etc. Booster stays. See the link twolo posted above - it really is the definitive source for all Fox brake tinkering.
Shadow 1
33
Gresham, OR
Mar 14, 2007
#10
  • Mar 14, 2007
  • #10
Thank you, I like the four eyes. So the master cylinder needs to be changed even though the rears stay drums, interesting. I'm going to have to re-read that website, I must have missed it. Thanks for the heads up. Oh, I like that website. Congrats to whoever wrote it.
SVT32VDOHC
3,501
28
119
Motor City
Mar 14, 2007
#11
  • Mar 14, 2007
  • #11
Shadow 1 said:
So the master cylinder needs to be changed even though the rears stay drums, interesting. :
My car started as a 4cyl so I did change the booster and master from the V-8 car. But I did leave the stock 4cyl proportioning valve. If my car was an original V-8, obvisouly I would have left it.
I don't know if the PBR set up will work with the 85 stuff, it's been a while since I ave looked at an 85 booster. If it is the big one I would say it would work. You will just have to give er the old trial and error method.
P
PJB
131
Rotterdam, NY
Mar 14, 2007
#12
  • Mar 14, 2007
  • #12
You dont need to change the master cylinder if youre sticking with drums in the rear.
Shadow 1
33
Gresham, OR
Mar 14, 2007
#13
  • Mar 14, 2007
  • #13
It's a pretty small looking booster.
Shadow 1
33
Gresham, OR
Mar 14, 2007
#14
  • Mar 14, 2007
  • #14
Cool, thanks. I took a look at it late last night and I might have to change it out anyway, my car was under water before I got it and it looks questionable. Do the lines have to be changed out as well?
Shadow 1
33
Gresham, OR
Mar 14, 2007
#15
  • Mar 14, 2007
  • #15
You know, I just thought of something. If you use ranger rear axles will it have the same 5-lug bolt pattern as the front conversion?
Bad92GT
The 5 Minute Plan Man
Jun 10, 2004
492
SC
Mar 14, 2007
#16
  • Mar 14, 2007
  • #16
yea it will.. im going full 96 on all corners with 00 GT calipers and the like on my 85 GT..
Shadow 1
33
Gresham, OR
Mar 14, 2007
#17
  • Mar 14, 2007
  • #17
Thats cool, how much do you figure the conversion is?
P
PJB
131
Rotterdam, NY
Mar 14, 2007
#18
  • Mar 14, 2007
  • #18
Yes. Mustang wheels fit on Rangers. Theres several Rangers around here with Mustang wheels too.
Shadow 1
33
Gresham, OR
Mar 15, 2007
#19
  • Mar 15, 2007
  • #19
Cool, thank's!
Bad92GT
Jun 10, 2004
492
SC
Mar 15, 2007
#20
  • Mar 15, 2007
  • #20
no idea for the consumer.. i work at a junkyard, so i happened to find it all out there and snagged it all.. i have about 80 dollars in new lines and pads in it.. thats all
1 of 2 Next Last
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
F
5 lug disc brake pad help
  • Foxrider714
  • Nov 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 17, 2025
KRUISR
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
A
90 Fox 4Lug rear convert to 5 Lug
  • adimice
  • Jun 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
limp
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
