twogts4us
NDBullitt said:There is no syncro for Reverse. There are 3 different things I do that don't make it grind:
1. Put the clutch in and leave it in for a few seconds then put it into reverse.
2. Put it into a different gear then put it into reverse.
3. Put the clutch in and start putting pressure to put it in reverse, then let the clutch out just a little bit as you continue putting pressure and it should slide right in.
Best, most accurate answer/solution.
