  • 1994 - 1995 Specific Tech
Question for Guys with Nitrous
  • Thread starter Thread starter Nobody
  • Start date Start date May 19, 2005
N
Nobody
2,515
Kenmore, WA
May 19, 2005
  • May 19, 2005
Where is your purge outlet? If your outlet is on the cowl, did you just drill through the cowl on both sides to get the pipe through?
Thanks,
Gabe
Vibora94
  • May 20, 2005
I marked the cowl where the pipe was going to exit and took both the cowl and the plastic cover in the engine bay off and drilled both of them. The cover was a little tricky since the hole was drilled at an angle.
N
Nobody
2,515
Kenmore, WA
May 20, 2005
  • May 20, 2005
Excellent. How do you take the plastic cowl off? Thanks
redsn95
38
Albany, GA
May 20, 2005
  • May 20, 2005
i just got right behind the weatherstripping and drilled through the plastic and ran 1/4 inch tubing through the holes
Vibora94
  • May 23, 2005
If you still want to take it off, remove the wiper arms off than pry the cowl from the base of the windshield with a large blade screw driver. Be carefull when you lift it off, the washer fluid hoses can snap of if the connectors are brittle.
K
Door post and rust repair
  • Kleinjj27
  • Aug 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
Kleinjj27
K
A
Catch can questions.
  • AngryH58
  • Sep 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2026
squeak93
Cooling Jacket Pitting Idea's?
  • BoostedRed89gt
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Mustang5L5
G
2019 GT Line lock
  • gray owl
  • Jul 18, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Jul 25, 2026
gray owl
G
94 kill switch wire question
  • MrPerfect2
  • Dec 11, 2025
1994 - 1995 Specific Tech Jan 10, 2026
fasterthangas
F
