I am wondering what kind of fuel pressure i should be running with my setup (look at sig).
Also I am getting the following codes
157 Maf sensor voltage too high
158 Maf sensor voltage too high
172 HEGO sensor lean bank one
176 HEGO sensor lean bank two
556 Fuel pump relay primary circuit failure
113 ACT sensor voltage too high
I have an Actron code scanner purchased from Advanced Auto Parts, and at first the thing only give me the codes for the EGR stuff i know what that is though, it repeated it twice and stopped. Then a few seconds later it started spitting out the other codes, i am assuming that this is the history of all codes that have came up since the last time that i have pulled them.
someone anyone tell me what problems this could be and if it is possible that any one these conditions are caused by low fuel pressure etc.
Thanks Jason
Thanks Jason
I just bumped his thread curious what fixed his problems since he has the same set of codes I do except for the MAF stuff..
