Question of Morality
  • Thread starter Thread starter Sixty Nine Mach
  • Start date Start date Jun 21, 2004
Sixty Nine Mach
10
Long Island
Jun 21, 2004
  • Jun 21, 2004
i have a 1969 all numbers matching car. the only different things on the car are a chrome manifold, air cleaner, valve covers and alternator and a 4 barrel. i have all the original stuff. i want the car to go faster. i was think heads and a small cam, but should i do it to that old engine? or leave the car totally stock??
Hack
1,945
Minneapolis
Jun 21, 2004
  • Jun 21, 2004
I don't think it's immoral to change the car. Just immoral if you go to sell it and lie about changing it.
I think you should do what you want with the car. Just remember that changes will reduce its value.
Good luck.
69 302/351c
1,147
Walkertown NC, originally Western Mass
Jun 21, 2004
  • Jun 21, 2004
Mine are both coupes, less desirable to some than a Mach, but I went into the motor on my 302 with 125000 original miles on it. Now I have 172000 and the block has never been out of the car. Still have good oil pressure and the cleanest oil I have ever seen.
I never plan to sell ( told the wife to consider it my life insurance policy) so I do what I want to the car, not what others say I should..or shouldn't.
MustangPaul
514
South East Louisiana
Jun 21, 2004
  • Jun 21, 2004
Maybe this'll make you feel better, but if you swap things, keep what you swap. If you sell the car, pass on the parts to the next owner. If they want to put it back, they have most of what they'll need. The next owner will thank you.
Snail50
787
Miami
Jun 21, 2004
  • Jun 21, 2004
it's your car, do what really makes you happy with it....don't deny yourself complete enjoyment of it just because of what a future buyer might think. It doesn't sound like your car is a rare model, so some well-chosen performance upgrades might actually raise the value of the car...
Also, you might be able to do some porting on those stock heads to improve the flow, which, along with a mild cam, should give you more power without changing appearance.
Snail50
787
Miami
Jun 21, 2004
  • Jun 21, 2004
and BTW, my 67 is/was an all original (except for new headliner, radiator, and exhaust)California black plate show car, and I had it for about two weeks before I started modifying.
T
TT670
360
9
28
Jun 22, 2004
  • Jun 22, 2004
Go for it, as long as you're not cutting the car up making mods that cant be easily reversed who cares. Like was said its your car and you wont be decreasing the value one bit as long as you hang on to all of the original parts.
Max Power
1,774
St Paul
Jun 22, 2004
  • Jun 22, 2004
Modifying old cars has nothing to do with morality.
Save your old parts. You can return it to stock if you see fit.
67GTA-FB429
777
Tri-Cities, Wa
Jun 22, 2004
  • Jun 22, 2004
Pull the original motor and put it in storage. Buy a new motor that you are going to build up. That is the best way to do it.
It is your car, you should do what you want.
PoliceInterceptor
Keeper Of Automotive Oddities
2,161
Live in GA, But could be any where really.
Jun 22, 2004
#10
  • Jun 22, 2004
  • #10
I agree,
If you don't do this, absolutely don't modify any of the original parts, and save them all.
While a 351 Mach isn't particularly rare, it is still a collectable and if its other wise nice grinding on the OEM heads could be a several thousand dollar mistake.
JMHO
Snail50
787
Miami
Jun 22, 2004
#11
  • Jun 22, 2004
  • #11
Not to hijack, but I still have my drum brakes and 14" wheels/hubcaps sitting around after converting to 4 wheel discs. I can't imagine that I'll ever want to convert back, because concourse doesn't interest me.
Are the parts worth keeping around, maybe for the possibility that some restorer will want an original set of drum brakes and 14" steel wheels? My 67 is by no means a rare edition, but it is in very good, mostly all-original condition (except for what I've done to it ~
I hate to get rid of parts anyway, but I don't want these things cluttering up my garage.
PoliceInterceptor
2,161
Jun 22, 2004
#12
  • Jun 22, 2004
  • #12
Snail50,
I'd probably keep them around if they are in useable condition. They won't bring much to sell, and you never know what an original 67 coupe might be worth down the road.
I'm a bit of a packrat though.
65fastback2+2
1,229
Louisville, KY
Jun 22, 2004
#13
  • Jun 22, 2004
  • #13
i agree. what if you modify it, and the motor is weaker than you think, or the added power causes u to throw a rod and make a nice big hole in the side of your block??? then all originality would really be lost.
Snail50
787
Miami
Jun 22, 2004
#14
  • Jun 22, 2004
  • #14
PoliceInterceptor said:
Snail50,
Thanks, PI. They are def. in useable condition, and i hate to get rid of anything that still has some life left in it. LOL, I guess I'm a packrat too.
U
ucstang
14
#15
  • Jun 22, 2004
  • #15
Just an opinion, but somewhere along the line we have been influenced by the economics of owning a collectable car. We used to buy hot cars and make them hotter, but now someone said, " If you do that it may not be worth as much, because it is not original". I think you alone have to decide what your car is to be. Glenn
BBRacer
99
Calgary
Jun 22, 2004
#16
  • Jun 22, 2004
  • #16
Agreement here as well.
I agree,
JMHO
Keep the old stuff and have fun. You may yourself change your mid later and want to "put it back". Most importantly - Have fun!!
P
Vacuum
  • ProTechAutoServices
  • Aug 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2026
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2026
DPP
D
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
