Right now I have a 289 thats .60 over, with weiand stealth intake, edelbrock 600cfm carb, ford tri-y's, dual flowmaster 40 series with H pipe, elgin cam which is .496 lift forgot the other specs but its pretty mild it seems. 3.55 gears, 2000 stall converter.
right now the engine makes about 260hp and 280tq
I was wondering If i got a set of GT40 heads and ported and polished them and increased the valve size, Got a custom ground comp cams camshaft close to .541 lift, and new rocker arms. how much power would it increase. also my powerband now is from idle to 5500rpm, but my intake can go from idle to 6800 so the new cam is going to be ground to be from like 2000 to 6500rpm. Those 2 parts should increase the power quite a bit right? im also going to add an edelbrock 100shot of nos to top that off.
Let me know what you guys think about the cam and heads.
