Question on fuel pump / bad ecu
5.0Torx
252
Hey guys,
So ive been reading so many search threads and looking at jrichkers/tmoss/stang+2birds diagrams and help pages that my eyes are glazed over lol.
I am among the group of unlucky saps who have had their fuel pump stay on constantly, and those help pages arent as specific for this issue as they are for the guys whose fuel pumps wont turn on at all. I finally read that if you unplug the ecu (i actually had mine out of the car so i could test the pins #46 vs 40 and 60) and turn the key to the on position, if the fuel pump doesnt turn on at all then you know the ecu is bad.
I just did that on my '93 and thats what happened.
Is that correct? I need a new ecu?
TIA!!!
I have replaced the fuel pump relay and the new one did the same thing as the old one. Just runs forever and ever.
I tried pulling the codes, but i dont think the ecu will give them to me until it stops priming the fuel rail, which in my case is forever. So i cant pull them.
On your car the ECU should send a signal to a red wire to the inertia switch. From the inertia switch the signal goes along a red and black wire to the relay. This should energize the relay and let it close to let the power flow to the fuel pump. It would seem that there's a constant voltage to the relay that's keeping the circuit closed. I'd put a meter at the inertia switch on the red wire with the ignition off and see if there's current. If there is then I'd say the ECU is bad. If not, then you'll want to continue trouble shooting.
Let me know if that red wire is always hot.
ECM doestn send a signal to the inertia switch in his car. Or the earlier Fox cars. The ECU only sends a ground to the relay. On earlier Fox's the Inertia Switch just shut off power to the relay. Later cars it just shut of the pump, and relay stayed energized.
Just ground the STI to the body.
Use a test light and clip the clip on the postive side of the battery. Stick the probe of the test light into the STO. Turn key on, but dont crank it.
See if codes flash.
