I've had a T-5z in my '66 for a while now, and am starting to work on heel-toe, and quicker shifting.
I'm struggling with consistency on the heel-toe and 2-3 upshift (seperate issues).
My questions are:
1). how many of you with classic Mustangs, have changed your pedal stops and readjusted the brake, clutch, and throttle contact stroke more in line like newer cars, so that you can just roll the brake with the inside of your foot and the throttle with the outside?
As it is now I have to use my instep, or heel on the brake and my toes on the gas, and I really suck at it.
I have no idea how I did it back in the 70's, and I seriously doubt I could ever get consistent with it again.
2). 2-3 upshift on a T5z. Stock shifter with a Hurst shift lever (for 83-89 Mustang), is what I have. What are you using, and are you able to make consistent quick shifts?
I can hit every gear except 3rd quick and consistently. And with the exception of my problems with Heel-toe my down shifts are pretty good too.
I'm thinking of moving the shift lever back a little closer, because I do have to move my shoulder to make the shift from second to third.
What have you done? and how does it work?
Oh yeah, I do have a console so I'm somewhat limited (as I put way to much work into the damned thing to take it back out).
Thanks,
Scott
My questions are:
Thanks,
Scott
Good luck.
