question on installing struts
riceslayer302
Banned
Oct 3, 2006
CT
im in the middle of putting my lakewood 90/10's in, and i have run into a little problem, the strut instructions say to use the ford bump stop? what is this part? i took my stock struts off and im trying to figure out how to get these new ones in the right way, i did it on the drivers side but im not totally confident, ive never done this before so im clueless, is there any write up or pictures that might help me figure out what order i put the dust boot, bump stop, and whatever oter bushings from the stock strut i need to use? need help on this one guys im pretty clueless. i dont want to screw this up. any pics of what your struts looked like before you put them in, or a write up would be a huge help! thanks!
the bump stop was the rubber bushing that is on the strut shaft under the plasic cover.it should go on first than the cover.i woudlnt worry about it to much i left mine off and i was going to put them on at a later time but when i read they have to come off when i install my caster camber plates i just left them off permanatly. phil
so you left the dust cover off and just put the bump stop on? none of the other parts that come off the stock strut should go on? i put the dust covers on with the bump stop inside it. thats the right way then?
