Question on trick flow's 351 lower?
  • Thread starter Thread starter Numbles
  • Start date Start date May 16, 2005
Numbles
998
Chicago, IL
May 16, 2005
  • May 16, 2005
Does anyone know If I can use a 351 R series lower with a track heat upper. Obviously I would have to open up the runners on the upper plenum to work. Will it physically bolt up. Im looking to run a 351 and would like to keep the same upper intake because its painted to match the car and I dont want to swap to the bigger upper. Another hood isn't in my budget. Thanks
Dan.
Numbles
998
Chicago, IL
May 16, 2005
  • May 16, 2005
ttt
Numbles
998
Chicago, IL
Dec 9, 2005
  • Dec 9, 2005
ttt
Grn92LX
Fidanza Man!
6,819
64
129
New York
Dec 9, 2005
  • Dec 9, 2005
It should bolt up as I beleive the bolt pattern is the same but the ports will be quite a bit smaller than the R ports. I put an old street heat gasket to my R lower and it wasn't even close but I think the bolt pattern is the same.
Numbles
998
Chicago, IL
Dec 10, 2005
  • Dec 10, 2005
Would you be able to double check on that for me. I cant call trickflow since its the weekend.
Trick Flow Series R to Box R Upper Intake Road Block
  • Habu135
  • Mar 31, 2026
  • 2 3 4
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
Habu135
SOLD Trick Flow Box R Series Upper Intake w/90 mm Inlet
  • Habu135
  • Apr 30, 2026
  • Engine and Power Adder
Engine and Power Adder Aug 19, 2026
Habu135
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
WTB/Trade In Search Of Trick Flow 351w R series EFI manifold Lower
  • Swhitney
  • Jan 20, 2025
Engine and Power Adder Jan 20, 2025
Swhitney
