Question on trick flow's 351 lower?
Numbles
998
Chicago, IL
Does anyone know If I can use a 351 R series lower with a track heat upper. Obviously I would have to open up the runners on the upper plenum to work. Will it physically bolt up. Im looking to run a 351 and would like to keep the same upper intake because its painted to match the car and I dont want to swap to the bigger upper. Another hood isn't in my budget. Thanks
Dan.
It should bolt up as I beleive the bolt pattern is the same but the ports will be quite a bit smaller than the R ports. I put an old street heat gasket to my R lower and it wasn't even close but I think the bolt pattern is the same.
