- Oct 30, 2016
- 11
- 0
- 1
I recently had a on3 turbo kit installed and even though ive seen poor reviews on the kit i am actually shocked with how well everything fit and worked out. My main concern is that the fuel pump harness clip broke and wiggled off while driving under boost. Now the question is, would that have caused detonation and in return caused the headgasket to blow? Ive blown two sets of headgasket before realizing this could be my issue. Unfortunatly now that ive blown my headgasket again and also done significant piston ring damage (soo much blow by my car looks like thomas the tank engine) Im now just going to swap in a new 5L. Long story short again , can a fuel pump failing under boost cause detonation and cause the headgasket to blow? Thanks I am new to the forum.
. " i beleve the fuel pump harness fell off because the clip was broken when i hit a bump in the road" that caused detonation and blew my gasket. It would have rand fine on the dyno because its not bouncing up and down, yknow?. My question was could the fuel cut and the continuation of spark and air cause the gasket to blow.
