  • SN95 4.6L Mustang Tech
Question when running a Lightning MAF
  • Thread starter Thread starter AllAboutSpeed
  • Start date Start date Aug 26, 2006
A
AllAboutSpeed
  • Aug 26, 2006
Hey guys I bought a used Paxton kit with a lot of stuff missing and just have a quick question. The kit has an Anderson power pipe and a Lightning MAF. Well I was curious... the lightning MAF has 6 pins and I believe on my 02 GT it has 5. I could be wrong on how many mine has im just going from memory. Will i need some kind of aftermarket wire harness to utilize this MAF? Where can I pick one up at? And second of all I need an adapter for the MAF so I can put an airfilter on it. Does anyone know where I can find one at? Thanks for the help.
Mark
jstreet0204
939
Winston Salem, NC
Aug 26, 2006
  • Aug 26, 2006
No, it plus right in. You will, however have to have the transfer curve added to the tune, so don't forget to tell your tuner you have it.
A
AllAboutSpeed
  • Aug 26, 2006
Oh really?? Well that makes me a little bit happier. Will i even be able to drive the car to the tuner with it installed??
I realize they arent tuned for anything and that I will deffinetly need it to be tuned. I just want to make sure I can limp this thing down to my tuner. Hes about 45 min away.
MY Cobra
308
Franklin NC
Aug 26, 2006
  • Aug 26, 2006
I got one on my twin turbo it will work but you got to get a tune. good luck ~NICK~
jstreet0204
939
Winston Salem, NC
Aug 26, 2006
  • Aug 26, 2006
That's probably not a good idea. Your maf is going to be way out, and so are your injectors. You are probably going to run so rich, that your plugs aren't going to worth a damn once you get there, and you may contaminate the the o2's that's if you can get it to run well enough to drive that far. You might try to figure something else out, like getting him to send you a base tune for you mods first, then drivin down to the dyno to teak it.
A
AllAboutSpeed
  • Aug 26, 2006
Thanks I will give him a call and ask him. Thanks for the help guys!
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
