Hello,
I recently purchased an AEM gauge-type wideband O2 sensor and controller (30-4100), which has a Bosch LSU4.2 Universal Exhaust Gas Oxygen (UEGO) sensor.
I have the stock exhaust, and want to keep it that way, in order to pass California emissions.
I was wondering where I should install the sensor. Should I install it in front of the front cat? Should I install it between the front cat and the rear cat? Or should I install it behind the rear cat, where the stock rear O2 sensor is?
If I install it in front of the front cat, then it seems like it should be the most accurate. Also, this is what AEM recommends. However, AEM recommends that it be at least 18 inches from the exhaust port, and I'm wondering if it will be too close to the exhaust port if I install it in front of the front cat.
If I install it between the front cat and rear cat, then it will definitely be more than 18 inches from the exhaust port.
If I install it behind the rear cat, then I can use the stock bung, and I won't have to weld in a new bung. I can just re-install the stock rear O2 sensor for an emissions inspection.
Will it be accurate if it is installed between the front cat and rear cat, or after the rear cat? Is there a formula somewhere to convert the lambda to A/F if it is installed after one or both of the cats?
Finally, do you think I should remove the exhaust, in order to drill the hole for the new bung? Or is there a way to minimize the amount of metal that gets into the exhaust, which would allow me to drill the hole without having to remove the exhaust? Is it difficult to remove the exhaust?
