I'm in the market for a set of aluminum heads for my 351w, preferably Trick Flow or Performer RPM. I see them on ebay all the time, selling pretty cheap. They usually come off Fox cars though, with 5.0s.
Will these heads work on my car?
I see some are setup for hydraulic roller cams... do you need to do anything for them to work with hydraulic flat tappet cams?
For heads that came off 5.0 cars... is the only change the length of the bolt length?
I also think the tolerances on the later 351w's differs from that of the older ones (deck height differences, etc)... does that impact selection?
Finally, I see a bunch coming with roller rockers, which I see as a big plus. Will 1.65 or 1.7 roller rockers off a head that was on a 5.0/302 work on the same heads with a 351w (probably different pushrod lengths, but I'd figure the rockers would work).
There may be other differences/things to look out for as well. Any information is appreciated.
