By the end of this summer I would like to have installed a mid pipe cat back and something for my aode. First of all for the mid pipe im thinking of the VRS o/r x-pipe I think its around $130, I keep hearing how x-pipes make more power so that is my reasoning for that. As far as the cat-back I would like something that makes power but is not too loud. My friends have magnaflow set ups on their cars and I think they sound good, I have also heard the dynomax cat back is good, I have seen that for $279.99 and the magnaflow for $399.99 are these fair prices? Is their a better setup out there? Now for the aode I have heard that shift kits not only help with shifting faster but also help with the life of the aode. I have never been to found of the idea of a shift kit because you need to drill into the stock valve body. However I was thinking of three things.
1. Shift kit and buy a stock valve body and use that to drill into
2. This is the cheapest valve body I have seen However I dont want to sacrafice quality for price
3. Chip
Now as far as a chip goes I have heard you since the 94-95's are controlled by the computer u can get a chip to act as a shift kit, correct? If I where to go this route is a chip something that I can order then just plug it into a port and then remove it if I ever want to, sort of like a plug and play? Also does a chip help prolong the life of the aode as much as the shift kit would?
Thanks for any suggestions or feedback you all can give me.
3. Chip
