questions questions questions !!
  • Thread starter Thread starter Spanish Dave
  • Start date Start date Jan 22, 2004
Spanish Dave
147
Oliva, Valencia, Spain
Jan 22, 2004
  • Jan 22, 2004
I need to know whether the pistons which I have ordered for my 289 f/b will work ok with Edelbrock performer rpm heads. The pistons are Keith Black Silv-O-Lite Signature Series Pistons flat top, hypereutectic, cast piston set. It is just that the Edelbrock site says that aftermarket pistons have to be notched for clearence .... and I don't know if these are. I don't want to order the heads if they wont be compatable. Also it states that they will not accept rail rockers ... but what rockers do I need?? Also it is unclear if these heads come with rocker studs ... anyone bought a set recently that could let me know on that one. Are these the best heads for value and performance that I should be buying? I was going to use a Comp cams Magnum 280h cam together with my existing weiand stealth 180 manifold with a holley 650 carb ... would this be a good combination? My buddy says to ditch this lot and go for a full *dyno matched* Edelbrock setup with cam, inlet manifold etc.
68GEETEE
5 Year Member
Nov 21, 2003
481
Texas, USA
Jan 22, 2004
  • Jan 22, 2004
I am not an engine rebuilder, but I do know there is a difference between notched and flat top pistons. If they are saying to use a notched piston, its because the valves need the clearance to avoid hitting the piston, as apparently it would if you had flat tops.
D
First post 289 rebuild question!
  • Ddyer2868
  • Nov 24, 2025
Classic Mustang Specific Tech Dec 5, 2025
rednotch
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Wednesday at 10:20 AM
KRUISR
9
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Today at 2:12 PM
mattcrp1
M
