questions
  • Thread starter Thread starter bvav22
  • Start date Start date Jun 23, 2007
bvav22
93
Michigan
Jun 23, 2007
  • Jun 23, 2007
i just put my bbk shorty headers on with an o/r x pipe. i took it for a drive around the block and it drove very well. however when i got under the car after to see if there were any leaks i noticed that the driver side o2 sensor was smoking, the smoke seemed to be coming from out of no where on it.... i shut the car off, then the smoke proceeded out the mid pipe. the smoke was white and was not very thick. any ideas on what could have caused that?
secondly, my dipstick was hard to get back in after the header install, i cant even really check my oil now becuase it wouldnt go in ALL the way. how can i get it to fit nicely.
bloopbloob
578
Alberta
Jun 23, 2007
  • Jun 23, 2007
not sure if this helps at all, but after my chrome bbk LT headers and x-pipe were on, they made a bad smell for almost 2 weeks. i'm guessing some of the coatings on them were just getting burnt off. i didnt notice any smoke though. just thinking it could be a possibility with your car though....
bvav22
93
Michigan
Jun 23, 2007
  • Jun 23, 2007
yea there is a very distinct smell coming from somewhere. and now my check engine light has turned on.... it didnt even turn on when the o2 sensors were off...
cjones
1,561
Avondale, AZ
Jun 23, 2007
  • Jun 23, 2007
time to pull the codes.
can you bent the dipstick tube so you can get the stick all the way in??
bvav22
93
Michigan
Jun 23, 2007
  • Jun 23, 2007
i bent the hell out of that little dipstick lol, it went 85% of the way in, but wont go any further.
is there a difference between left and right o2 sensors?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 23, 2007
  • Jun 23, 2007
Both LH & RH O2 sensors are the same. A failing O2 sensor or vacuum leak will set code 41 or 91.
bvav22
93
Michigan
Jun 24, 2007
  • Jun 24, 2007
ok thanks ill have to get to autozone this week and run codes.
however before i went out tonight, i took the car for about a 2 mile drive, the check engine light did NOT come on, and the first time it did i only took it about a 1/4 mile
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
R
bbk shorty header to mid pipe gasket
  • randyyy
  • Sep 29, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2025
randyyy
R
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
F
Fuel Idle Chops With No Cam
  • FiveOhGabe
  • Oct 30, 2024
Fox 5.0 Mustang Tech Oct 30, 2024
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
