Questions.
AnthonyR23
661
Ontario
1. I have a deep sump oil pan on my 347. I topped it up to the normal point but it seemed like alot of oil.. about 7 or 8 litres. Is that normal. Just seems like alot.
2. So I got high flow pypes catalytic converters and installed them on my offroad x pipe. The smog tube is just before the x on the x pipe, and I had to install the converters before the tube. These converters have spots for 02's right on the converters, so I am thinking they are probably the new kind that doesn't absolutely require the smog pump. Will they be okay?
3. Can wrong timing cause hesitation and high idle. Kinda backfired a couple of times but that could be because of a lean condition. Had to replace my 02's. So am going to check it out tomorrow. Just want it to run smooth!
