Quick...about to order...will this oil pump primer work (1/4 in. hex pump shaft)?
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Vendor: Milodon Inc.
Product Line: Milodon Oil Pump Primers
Material: Chromemoly Steel
Finish: Black Oxide
Prevent needless engine wear.
Ford: 289/302/390/428, with 1/4 in. hex pump shaft, oil pump primer
Before starting a new engine, proper priming of the oil system is absolutely critical. This oil pump primer eliminates engine wear from improper lubrication upon initial startup. This primer allows you to drive the oil pump with a 3/8 in. drill once the distributor is removed. It is made from black oxide chromemoly.
Sold individually.
Thanks David
