Quick, Air pump Line Questions...
the smog tube??? if so, then it goes inside or thru the crossmember, then will connect right to the tube...its a mofo if the crossmembers in place....i had to remove mine not to long ago...i just cut the freakin thing as i couldn't get it out of the crossmember...
Edit...the pic show it thru...
If its not bent to bad??? i took a hacksaw cut like 4"-6" towards the header collector side, from that bracket that bolts to the frame, thats all it takes to get it in...then just clamp that hacksaw cut....hose would be easier, but may burn thru in time???
That little tube can really jerk you around trying to get in in with the motor in place....i learned that one.... :bang:
