  • 1994 - 1995 Specific Tech
quick and last gauge question help please
  • Thread starter Thread starter 91LX_5L
  • Start date Start date Nov 5, 2004
91LX_5L
1,943
British Columbia
Nov 5, 2004
  • Nov 5, 2004
Oil Pressure, and Water Temp are the main aftermarket gauges I only really need right? Are these two pretty straight foward to install, there electrical. What about the fuel pressure gauge is that a hard one to install, is the fuel rail version much cheaper and easier?
thanks a lot!
94TURBO5 O
2,509
VA
Nov 5, 2004
  • Nov 5, 2004
They are both very easy to install. There is a fuel rail gauge you can get if you want. If you need help on the install just let us know.
91LX_5L
1,943
British Columbia
Nov 5, 2004
  • Nov 5, 2004
what about a in car autometer fuel pressure gauge?
94TURBO5 O
2,509
VA
Nov 5, 2004
  • Nov 5, 2004
Yes the electrical one is easy to instal but is a lot more $$$ than the fuel rail mounted one.
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
Nov 5, 2004
  • Nov 5, 2004
If you are not running any power adder, I would not waste the $$ on the FP Gauge for now..
If you want 2, the WT and OP are it.!
If you mount them together, you can splice the power source line, the light dimmer line, and the ground line together, then connect them to a single source.
Then, each sending wire will go to it's respective place....
You will get an Oil sending unit that replaces the stock one near the oil filter, and connect the sending wire to IT.
You will get a water temp sending unit that will either replace the stock one in the lower intake just to the right of the distributor, OR you can get an after market water neck that has a screwhole in the top to install a sending unit.
Since the one in the intake is more accurate, I installed the Autometer one in the intake, and move the stock one to the top of the waterneck in the screwhole provided, just to have both working..
Ill find a couple of pics to post for you.
RC
94GTLaserRC
11,178
Nov 5, 2004
  • Nov 5, 2004
Ok...Here is the location..
DOnt JR, it's an OLD Engine pic...PRE-BLING!
RC
blksn955.o
3,263
st.louis mo 314
Nov 5, 2004
  • Nov 5, 2004
could you run the stock guage also off the autometer sender?? or does the voltage get screwed having to see 2 guages? I am looking into getting a water/n2o inside and a FP outside by spring and wanted to know if the same sender could work both stock and autometer guages?
Also there are 2 ranges of temp guages offerd in autometer's line, looking at the 2 1/16 elec. elec. guage, which one is best? or is one a full sweep elec. and one not?
HISSIN50
34
129
Nov 6, 2004
  • Nov 6, 2004
dont run two gauges off one sender. best case, each reading would be cut in half. if each gauge is calibrated differently (likely), they would just plain be off by an unguessable amount.
for water temp gauge, what one could do: put the new gauge in the stock location. in the rear of the lower intake on the driver side, there is an unused port (on foxes, atleast). relocate the stock sender for the stock temp gauge back there. that location is less accurate but atleast it works and the gauge is not dead.
some also use thermostat housings, etc as a location for a sender.
good luck.
OrangeMustangGt
1,976
Cape Cod, MA
Nov 6, 2004
  • Nov 6, 2004
yeah if you goto auto zone and get a new waterneck, it comes with a fitting that has a threaded plug on the top, its only 8$, and it includes the gasket. i got the one for a fox cause thats all they had, but its the same.
C
Fuse help please. 73 Mach 1
  • Curtis Harper
  • Oct 19, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 28, 2026
Curtis Harper
C
Progress Thread Sask84gt's 84 GT - Questions and Progress Thread
  • Sask84gt
  • Oct 13, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
Sask84gt
  • dan50
  • Jul 18, 2026
dan50
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
A
88 Foxbody Starts but Stalls When Warm Please Help
  • airforcerob
  • Apr 2, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 4, 2025
