quick converter question
  • Thread starter Thread starter SPEEDYLIFSAVR
  • Start date Start date Sep 6, 2006
SPEEDYLIFSAVR
666
FL,89 LX 5.0
Sep 6, 2006
  • Sep 6, 2006
I am helping a buddy replace his AOD tomorrow with one I recently pulled from my car when I did my conversion . My question is about the converter , how much fluid should be in there , I noticed what appeared to be a fill hole next to one of the bolts that hold the converter to the flexplate , is this where you fill it?
TC93
Well-Known Member
Sep 11, 2000
2,075
Ellerslie GA 31807
Sep 6, 2006
  • Sep 6, 2006
Pour a quart in there before installing the converter into the trans. Once the tranny is installed add about 5 quuarts start it foro about 3-5 seconds, and 3 more then restart and run through the gears. If all gears are engaging,, take for a ride to get tranny up to temp and check fluid level. Add as nessecary..
L
lxarlo
21
  • Sep 7, 2006
if the converter is completely dry, yea you can add about a quart, or a little less just to get the clutches wet. dont add any more because if you do, its just goin to spill all over the place when you are trying to spline it to then input shaft.
SPEEDYLIFSAVR
666
FL,89 LX 5.0
Sep 7, 2006
  • Sep 7, 2006
Great , thanks for your replies!
C
Electrical Under dash wiring
  • ChicagoMustang
  • Apr 17, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
Resolved 1999 cobra removed lower intake manifold to crossovertube
  • hvcobra99
  • Sep 6, 2026
  • SVT Tech Forum
SVT Tech Forum Sep 6, 2026
hvcobra99
Progress Thread 91GTstroked 90 7 up convertible build
  • 91GTstroked
  • Apr 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 22, 2026
91GTstroked
Drivetrain Witness marks on Torque Converter
  • Mcmahst
  • Mar 19, 2025
Fox 5.0 Mustang Tech Mar 21, 2025
85GTStangGuy
D
Negative Grounds for 2008 4.0L
  • deadbeat
  • May 13, 2026
  • 2005 - 2014 Specific V6 Tech
2005 - 2014 Specific V6 Tech May 13, 2026
deadbeat
D
