Quick Fox TB swap question...
Pretty much. If you have the intake, TB, TPS & IAC, you're gonna need an EGR valve (or EGR delete plate), and a cap for your EGR bung in the stock header.
You will also need to swap the throttle cable (and cruise cable if you want to keep cruise) to a fox style.
thats right.
if you plan on running a stock fox upper like i did, i ran it with the egr spacer first then made my own egr delete plate but the throttle bracket was hitting the heater tubes so i had to clearance it.
