  • SN95 4.6L Mustang Tech
Quick Help please!!!
  • Thread starter Thread starter Chaos A.D.
  • Start date Start date Mar 29, 2006
C
Chaos A.D.
46
Webster, MA
Mar 29, 2006
  • Mar 29, 2006
ok, so i fell for the whole intake spacer and TB spacer thing. i just got them in, bolted it all up, plugged the sensors back in, reconnected the battery.....and now my car stalls. wtf? everything seems ok. doesn't seem like there is a leak. any ideas? i'm desperate. i'm going to go check it all again. i'd just take the spacers out, but that won't necessarily solve my idle problem. f***. anyone...please? thanks...
joe
Dan_Soprano
7,410
54
129
Jacksonville, FL
Mar 29, 2006
  • Mar 29, 2006
joe
is the plug on the IAC valve connected all the way??
C
Chaos A.D.
46
Webster, MA
Mar 29, 2006
  • Mar 29, 2006
not sure. i don't even know what i'm doing. just a go-getter kind of guy. is that one of the plugs by the plenum that i had to disconnect? sry.
M
mac1009
187
Atlanta, GA
Mar 29, 2006
  • Mar 29, 2006
What type of stalling? Does it hold an idle at all, die when you give it gas, stall randomly?
C
Chaos A.D.
46
Webster, MA
Mar 29, 2006
  • Mar 29, 2006
it turns over and then just dies. it tries to keep an idle for about 1/4 second and then stalls.
Dan_Soprano
7,410
54
129
Jacksonville, FL
Mar 29, 2006
  • Mar 29, 2006
sounds like the IAC plug is off.........same thing happened to me......the plug wasn't pushed in all the way.
Dan_Soprano
7,410
54
129
Jacksonville, FL
Mar 29, 2006
  • Mar 29, 2006
it would be this plug:
C
Chaos A.D.
46
Webster, MA
Mar 29, 2006
  • Mar 29, 2006
i just off the stupid TB spacer, plugged everything back in....and still the same problem. i have the intake spacer on there still, but that's so small it doesn't seem like taking it off would do anything. i'm thoroughly frustrated and out of ideas. i'll check the IAC plug again, but i just put it on, and it clicked in place.
C
Chaos A.D.
46
Webster, MA
Mar 29, 2006
  • Mar 29, 2006
ok. it's back to stock now....still stalling. can anyone help while there is still daylight? please?
M
mac1009
187
Atlanta, GA
Mar 29, 2006
#10
  • Mar 29, 2006
  • #10
Double check everything. Hose on the back of the plenum, pcv, iac, tps, and maf connections.
Do you have a code reader to see if it's throwing any codes?
M
mac1009
187
Atlanta, GA
Mar 29, 2006
#11
  • Mar 29, 2006
  • #11
Also, if you give the car gas when you try and start it, does it run?
C
Chaos A.D.
46
Webster, MA
Mar 29, 2006
#12
  • Mar 29, 2006
  • #12
no, don't have a reader. i'll check the connections again, but i've checked a few times now. wish there was someone nearby to help. this sucks
C
Chaos A.D.
46
Webster, MA
Mar 29, 2006
#13
  • Mar 29, 2006
  • #13
it will run with my foot on the gas, but dies if i take it off
C
Chaos A.D.
46
Webster, MA
Mar 29, 2006
#14
  • Mar 29, 2006
  • #14
could it have anything to do with the EGR? i had to undo the two bolts to lift the plenum up for the spacer, i tightened it as much as i could, but i did't have a new gasket for it. ??
M
mac1009
187
Atlanta, GA
Mar 29, 2006
#15
  • Mar 29, 2006
  • #15
Doubtful. I pulled mine off last weekend and the gasket was shot, and the car was fine w/out a new one. Did you check the vacuum lines between the TPS and IAC? If you want, grab a few pics of things and maybe something will stick out.
C
Chaos A.D.
46
Webster, MA
Mar 29, 2006
#16
  • Mar 29, 2006
  • #16
ok.....delete this post. even though i checked the car over fifteen times, it seems there was a hose that came unplugged underneath the intake arm. it was very hard for me to see until i took the intake off of the TB again to make sure i wasn't missing anything. thanks for all your help. think i'll just sell the spacers. everyone seems to think they are a waste anyway. i'll just wait for the accufab stuff. thanks so much again.
M
mac1009
187
Atlanta, GA
Mar 29, 2006
#17
  • Mar 29, 2006
  • #17
Glad you got it all worked out. I couldn't tell you how many times I've gone over something 100 times, and yet I've overlooked the stupid problem every time.
M
Need help please
  • Mikey62666
  • Oct 12, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 14, 2026
gkomo
  • Gulftown980x
  • Jul 29, 2026
squeak93
L
Help with 1986 GT 5 Speed Please
  • Lcasada1999
  • Mar 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
F
86 notch NEED HELP!!!!
  • foxbody86
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2026
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
