quick q on Fuel connector removal tool
mity2
I like Pro3 and all I got was this crappy CT.
Jul 24, 2003
2,872
StateCollege PA
quick q on Fuel line connector removal tool
I'm changing Fuel filter today, and i need to go get fuel line disconnect tools. they have two different size removal tool. one is 3/8, and other is 5/16. which one do i need?
grrrrr someone appearentlly changed Fuel Filterbefor, butdidn't use proper tool to remove the connector! engine side of connector pin inside of flear is all acrewed up. I had to cut the rubber line to get the darn thing out!!!!
ya i cut the line off(which was not easy due to location, and fact Ford OEM rubber gas line has hard plastic inner liner, and then i cut the filter nipple off, and use fine point needle to push pin off. what should have takin me 20moin now taking over 2hours...
