  • SN95 4.6L Mustang Tech
Quick question about DeMolet CAI
  • Thread starter Thread starter 03MustangGT
  • Start date Start date Sep 6, 2005
03MustangGT
43
Pennsylvania
Sep 6, 2005
  • Sep 6, 2005
When installing the full length unit, I used both elbow pieces and installed the filter in the "down" position on my 03 GT. I didnt have anything to use to more firmly secure the elbow piece thats attached to the air filter to the elbow piece that attaches to the MAF. The two pieces simply fit together pretty snugly, and the whole unit was pretty solid. My question is, should there be screws connecting the two elbow pieces at the cover plate? Im a little worried I may hit a pothole or something and jar the thing loose. I drove the car around for a bit once I was finished and there were no problems, but I still thought I'd ask just to be sure. Thanks for your help.
mdvaldosta
72
  • Sep 6, 2005
yes, theirs a hole on the outer rim for you to put a screw in. better do it before you drive down the road and it falls off.
04GT
284
Southwest Ohio
Sep 7, 2005
  • Sep 7, 2005
Mine came with three screw to secure the two elbow pieces together.
03MustangGT
43
Pennsylvania
Sep 7, 2005
  • Sep 7, 2005
It was getting dark last night when I put everything together, so I didnt notice the screw holes. I only found two of the holes, at least the two that I could see and I found two screws with screw caps in the bottom of the box. I screwed those in pretty easily so Im assuming everything lined up. The air filter sits down in the fenderwell and doesnt contact anything. The whole unit feels pretty rock-solid so Im assuming its ok. Thanks for your input
P
page90lx
15
dover tn
Sep 7, 2005
  • Sep 7, 2005
3 screws like they said
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
2001 Mustang GT -- Valve Assembly Pressure Regulator Solution Found!
  • SN95_fanx54
  • Aug 17, 2024
3K
SN95 4.6L Mustang Tech Oct 23, 2025
M
  • mnky99
  • Sep 5, 2025
mnky99
M
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
