Quick question on fan controllers
  • Thread starter Thread starter trents99
  • Start date Start date Jun 9, 2006
trents99
438
Hampton, GA
Jun 9, 2006
  • Jun 9, 2006
Ok please save your bashing because I know my current set up is wrong, it is being addressed now. My car came with an electric fan and the PO had it wired directly to a toggle, yeah, no relay or anything. So anyway it's worked like this for a year with no problems...until yesterday. I have a mechanical temp gauge and noticed yesterday while driving it was not cooling properly so I pulled over and checked the fan and it wasn't working. Luckily it's a straight shot home down the highway so driving temps kept it cool enough.
So on to the questions. I'm going to get the dccontrol unit and have read about wait times of 2,3,4 weeks to get it and in a more recent thread I read that they are produced on more of an assmely line now. Has the turn time on these been reduced? Reason being this is my DD and I need something fairly quick which leads to my other question.
I re-wired the original toggle to use the ground for the switch instead of the hot. The hot lead is fused at 30a and runs from the battery and I am just using the toggle to interrupt the ground essentially. Do you think I could get by with this set up until the fan controller arrives? Maybe go buy a 30a relay to help out in the meantime?
HISSIN50
34
129
Jun 9, 2006
  • Jun 9, 2006
Email Baskin and ask about build time right now.
What kind of fan do you have? Otherwise no one can help much with the current draw or whether a 30 amp relay will work. That said, I have switched ground to fans before and it worked fine for me. YMMV.
Good luck.
trents99
438
Hampton, GA
Jun 9, 2006
  • Jun 9, 2006
Good luck.
That might help
It doesn't have any model numbers/name on it anywhere but I'm almost positive it's not a JY fan. Looking through Summit it looks just like a Flex-a-lite. About 17'' diameter, straight blades, two wires so just off and high speed as the only settings.
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Resolved Holley terminator integration into CCRM
  • BrandonMP
  • Feb 25, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 23, 2026
fasterthangas
F
J
V-6 thermostatically controlled cooling fan - on when cold - new behaviour
  • jacekk
  • Oct 1, 2025
  • 2005 - 2014 Specific V6 Tech
2005 - 2014 Specific V6 Tech Nov 14, 2026
jacekk
J
F
AC Compressor Power & Contour Fans
  • Fri Guy
  • Aug 27, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 15, 2026
BoostedRed89gt
