Quick Question on the TwEECer System
  • Thread starter Thread starter vristang
  • Start date Start date Feb 16, 2006
vristang
4,933
101
124
Seattle
Feb 16, 2006
  • Feb 16, 2006
I am still looking into tuner units.
Can the TwEECer add parameter to what already exists in the ecu? For example could you tell the computer to use the factory formulas/tables for one set of conditions, say part throttle, and a separate set of tables for wot.
If not is there another program that does allow this much modification?
I think the PMS unit does, from reading other sites, but I can't say for sure just yet.
Thanks,
jason
ninety15.0
1,336
  • Feb 16, 2006
Yup....the tables in the tweecer system are a little confusing at first but they have some preprogrammed curves and then you can adjust each box individually. I think that most tables are either for WOT or they are for a specific function(MAF, Timing,...etc) vs. RPM or load. extremely adjustable though.
ninety15.0
1,336
  • Feb 16, 2006
that may have been a little confusing, i'm in class and cant really spend a lot of time explaining the details. PM me if u want some additional or more specific info as to what you are trying to control at part throttle/WOT. The computer also goes in and out of closed loop and open loop when your at WOT or cruising....generally your part throttle perameters get adjusted when its in open loop (using realtime readings from all sensors) so IMO the tweecer is less helpful in those conditions. all in all the tweecer is good software with some great features, but the learning curve is steep and it takes a lot of research, data logging, and experimentation to get things perfect. Lots of test rides !!!
vristang
4,933
101
124
Seattle
Feb 16, 2006
  • Feb 16, 2006
Ninety15.0 - I PM'd the same msg to you, respond however is easiest for you.
I don't mind, I love test rides
I saw a topic posted on another site about having the computer use vehicle speed to change when the electric fan is turned on. Basically the fan would turn on at a lower temp when the car is stuck in traffic. The stock computer did not use vehicle speed to determine fan operation, the vss input had to be added to the lookup tables. Obviously this would require inputs that are not stock on our computers, so maybe moving to an sn95 computer would be needed for this?
I don't really care if this specific example could be done or not, it just got me thinking. Something I would be interested in would be running the rad fan for a specified duration, or until a certain temp, after the motor is shut off. Or could an electric water pump be controlled the same way?
In general I guess I am curious about whether or not the TwEECer will allow the user to add variables/input signals to the existing tables. OR, can new tables be created from scratch.
For example, could I create from scratch a table that would use throttle position to send an on/off output signal to the Sound System?
OR, could I modify an existing table to use an imput signal that is not used by the factory programming.
I am just curious as to what the limits of the TwEECer are. I am leaning toward this over another system, because it seems easer to get support for it.
Thanks again
jason
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
PWM Fan Control
  • Mustang5L5
  • Feb 3, 2022
  • Digital Self-tuning Forum
  • 2 3
16K
Digital Self-tuning Forum Aug 10, 2023
SorsCode
Install Daytona Sensors CD-1 Ignition Mustang Fox SN95
  • revhead347
  • Sep 21, 2019
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 11, 2026
AeroCoupe
A
94' Cobra Dies with AC is on
  • Acj2001_Fordman
  • Jul 2, 2019
  • 2 3
7K
1994 - 1995 Specific Tech Aug 24, 2019
Acj2001_Fordman
A
M
I really wasn't expecting this....... First time Mustang owner.......
  • Mikedd969
  • Nov 27, 2019
3K
1996 - 2004 SN95 Mustang -General/Talk- Nov 28, 2019
Mikedd969
M
