quick seafoam question
fivespeedsteed
Oct 17, 2003
748
22
69
Richmond, VA
so i fed in maybe a third of a bottle into my car through the bb hose, (not off the tree, off the brake thing) and let it sit for 30 minutes. didnt do much.....my friends 99 gt did allot better, they did it the 4.6 way with a straw cup and through the hole on the tb or whatever. so how are you supposed to suck it in, fast so the engines always bogged, or little by little? once you get it all in how long should you wait to shut the engine off? like rush from the bay to the key? or just wait like 30 seconds?
i just want to make sure im doing it right. im thinking about leaving it overnight.
i removed the pcv from the pcv hose and sucked it into the intake that way i put the pcv hose into the container and allowed the engine to suck the seafoam until the engine died and let it sit for about 15 mins...crank it up and send some serious smoke signals....lol...have you drove it yet after adding 1/3 of a bottle if not drive it until the smoking quits...after adding seafoam the motor usually tends to idle without smoking too bad but when you get it on the road and raise the rpm,s it will smoke alot.
in my carbed car i held the throttle open by hand barely above idle, and slowly poured in half the bottle in both sides of the carb, when the bottle was almost empty i dumped the rest of it in till it dies(lower RPM's it will die easier), let it sit for 10min and fired it up with lots of smoke, i used the first half of the bottle on a friends car
~Mark~
EDIT: i didnt notice any more power, and you can also do the same thing with water if you're careful, it will steam clean the tops of the pistons
Yeah, it depends on how well you've taken care of things in general and, thusly, how much carbon is built up inside the intake/heads/combustion chambers. I douched my Lincoln Town Car's 5.0 with it awhile back, and it coughed up a few decent clouds of poop, but when I gave my notch the Seafoam flush ... ugh. My neighbors hated me. :D
Although the worst case scenario I've ever seen of Seafoam in use was a couple of kids that used it on some old Honda in the parking lot of Autozone; it was so bad, the resultant gigantic cloud of smoke was bad enough that some guys from the fire department station half a block away came rushing down, thinking that something had burst into flames. I don't know if the car really was that extremely carboned up, or if they somehow went crazy with using the stuff and somehow fed in too much too quickly or something to cause such a mess in the air.
I've re-treated the notch a few months ago, but it didn't put out much smoke at all, so I'll take that as a good sign that things have been staying clean. I don't use crappy gas, and I keep everything in tippy-top tune, so the carbon build-up over one year's time was minimal. I'd say do it once a year at most, only let it sit for about 30 minutes at the most before restarting. I didn't pull my PCV valve off - when I tried to, it stalled out the motor - I just pulled it from the grommet and slowly fed it through the PCV valve by pouring it really slow and steady from the can at a really light trickle ... just enough to bog the motor just a little bit, but not stall it out entirely.
I did my friend's little Mazda 2000 pickup the other say and it had some smoke from it, we've done it to a bunch of cars and always smoothed it all out but then eventually went back to normal after a few days. My friend from school, (he had No common sense basically lol) He had a brand new ranger he did it too, he must have put it in where it only got into one cylinder (not distributed to all the other cylinders) and he dumped ALOT in at once and he HYDROLOCKED his motor hah, I saw a pic of his rod on his phone, it was bent like a mofo....but he got lucky as hell cuz it was still under Ford warranty and he said it just happened all by itself or something, his bill came to like 10 bucks just for the gas they used....But im sure no one here is that dumb to do something like that. When I do it Ill bring the idle up a little but and pour it down the carb or through the main vacuum line whichever it has till is starts to bog, when im almost done with the bottle, ill bring down the idle and pour enough in to make it stall and let it sit for 5-10 minutes (we always do it in a random parking lot, we're not gonna sit there for 30 minutes) and then we start it up and wind out every gear, to clean everything out.
If I could give one bit of advice to anyone and everyone, it would be to never assume that people in general aren't actually "that dumb".
There are lots of people out there who do retarded things, and that applies to every interest or hobby. Mustangs too.
Just today I was driving my LX on the highway and passed a hotel that had a 5.0 in the parking lot. It had 20+" spinner wheels on it.... The kind you'd expect to see on an Escalade. Awful. Just, awful.
