  • Mustang Sound & Shine All
Quick sub and amp question
  • Thread starter Thread starter Makdaddymac
  • Start date Start date Aug 21, 2008
M
Makdaddymac
323
orlando
Aug 21, 2008
  • Aug 21, 2008
quick question sorry if in wrong place,
but i have a 600w 4 channel amp that is bridgeable, i bridged it and i didn't hear any difference......also the amp is getting hot, i would say its about 80-95 degress with about 10-15mins use....is this normal,
this amp sucks by the way...
sony 600w 4channel
4 x 55W RMS @ 4Ohm
# 4 x 65W RMS @ 2Ohm
# 1 x 130W RMS @ 4Ohm - Bridged
got it all cheap with a 12" pioneer in box
my sub is way underpowered, but it still thumps just not good enough for me....lol..i guess i should get a better amp. but my amp wiring kit say i have a 250 rms max, so if i get an amp that puts out 200w rms i should be ok right?
2BADSTANGS
385
Colorado
Aug 21, 2008
  • Aug 21, 2008
The temperatures you described are normal. If it burned your hand when you touched it, then you definatley have a problem. Most newer amps have thermal protection, meaning they will shut themselves off if they get too hot. What guage wire do you have run to the amp?
M
Makdaddymac
323
orlando
Aug 22, 2008
  • Aug 22, 2008
puny 8 gauge,i should be fine with that, since my amp barely puts out 130 rms bridged........the package said 550w max and 275 rms.....i coul be wrong though.....i know my sony amp will never go 550watts lol, and my rms will never go 130+ w/ one sub, so i should be fine with that right...
and yes my amp does have a auto shutoff/protector light that is working...
2BADSTANGS
385
Colorado
Aug 22, 2008
  • Aug 22, 2008
Yes, your 8ga will be fine to around 250- 300w rms, depending on the length of the wire. But as you have stated if youre looking for more bass, keep your eyes open for a better amp. By the way, is your sub dual voice coil, if so how many ohms is each one? How did you connect the outputs of the amp to the sub? I had the same problem wanting more bass and ended up going with an MTX 1501D 1500w amp and 2 MTX 7500 12''s. See below...
ChingonStang
308
Dallas, Tejas
Aug 22, 2008
  • Aug 22, 2008
I bet the baby riding in the car seat enjoys the heart stopping bass!
D
Drew0318
115
Chicago, IL
Aug 22, 2008
  • Aug 22, 2008
The amp is hot because of the lower impedance load (ohms). Any time you run an amp bridged, you're increasing the load on it, and thus making it work harder. You could also be over-driving the amp which will make it hot (and sometimes make the sound noticibly ****, if it doesn't just quit altogether).
An amp that small, you most likely won't hear any difference bridged/etc. There's not a significant difference in power output. The only way you'd really be able to notice a difference is if the speakers were extremely efficient (100-105db+). The only thing you're really accomplishing by bridging that amp (that specific amp) is making it hot.
2badstangs is on the right path. What's the impedance of the speaker/sub? I'm assuming it's 4ohm, but is it dual voice coil or single? These will play a major part in how the amp "sees" them and the load it puts on the amp. If it's dual, how you hook it up will make a big difference. 2 4ohm in series will be an 8ohm load, 2x4 in parallel will be a 2ohm load. It also depends on how stable the amp is at low impedance. Some amps can handle 1/2 ohm setups, while others **** themselves at 2.
Many, man, many years ago, I had a setup in my CRX (great car for it, two seats and a big ass hatch for a big ass sub cabinet) that had a pair of Lanzar 12" subs and a single Lanzar amp. I ran them bridged in 2 ohm which pumped 1200W to each one. I hit 147db on the SPL meter. The fun thing was setting off other peoples' car alarms about 100' away.
As a result, nearly 15 years later, I can't hear **** in a crowded room... ah, youth.
Run a 5 channel or use head unit and mono amp for sub?
  • 2000xp8
  • Sep 20, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 23, 2024
2000xp8
Problem With Sub And Amp No Output
  • mitchell allard
  • Sep 10, 2016
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Sep 13, 2016
mitchell allard
Help With Amp For Sub?
  • mitchell allard
  • Apr 2, 2016
2015 - 2023 (S550) Mustang -General/Talk Apr 4, 2016
mitchell allard
Progress Thread How Does A 96 Mach 1 Sound?
  • Anthony Bonert
  • Mar 1, 2017
  • SN95 4.6L Mustang Tech
2K
SN95 4.6L Mustang Tech Mar 10, 2017
Anthony Bonert
Budget Audio Build (f150 Upgrades Without Keeping Sync)
  • Adieu
  • Oct 28, 2015
2K
Mustang Sound & Shine All Oct 28, 2015
Adieu
