OK, I'm reinstalling my balancer, my distrib is out so I won't be using that as a reference. So I have to find TDC manually from the #1 spark plug hole.
I cranked till I knew it was on the compression stroke. Then I put a screwdriver in there to try to find where the piston hits the highest point. My problem is that it hits the top and then stays there for about 10-15 degrees of a rotation. Where should I set it so I can reinstall the balancer correctly? Right when the piston first hits the top, right before it goes back down, or somewhere in the middle?
BTW the engine is complete and the heads and valve covers are on. So I can;t see the piston
thanks
thanks
