quick vacuum line question
There should be a few small screws holding the splash shield to the ground effects and a couple of push pin holders holding it to the inner frame. Look around and start on the front slowly pulling the splash shield out. Why do you need to get to the canister??
alright i took it off and found a broken vacuum line, disconnected vacuum line, and the vacuum canister in there is busted? The plastic front piece is busted off the canister and the little stub thats comes out for the vacuum line is busted off into the rubber vacuum line. so i have to get a new vacuum canister?
alright so does anyone know what kind of vacuum canister i need to get? Im pretty sure thats the vaccum canister its right under the splash shield and covered with a rubber cover.
Is there a vacuum canister on the other side also?
