Racing wheel studs question.
  • Thread starter Thread starter Fett
  • Start date Start date Mar 8, 2007
Fett
766
  • Mar 8, 2007
Silly question time:
When a racing wheel stud is measured, how is it done? In other words, is a 3" racing stud measured from tip to tip, or is it just the threaded portion?
I bought some 2.5" wheel studs from Steeda, put them in the 5-lug axles that I am installing in my car on Sat.....never bothered to actually measure them. I held my axle up the inside of my rim, and the lugs stick out past my center cap. So THEN I decided to measure and they are 3" from the bottom of the head on the stud to the tip of the lug. But the threaded portion is around 2.5 inches. So I don't know if they sent me the wrong ones or if I am measuring wrong.
Either way I am going to have to either cut them down or replace them...again. h
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Mar 8, 2007
  • Mar 8, 2007
for a car to pass tech your wheel studs must be 7/16's of an inch sticking out past the lug nuts. as for how they measure them i would suspect its the threaded portion.
G
getusummm
156
  • Mar 9, 2007
All the bolts I have ever dealt with are measured from the end of the bolt to the bottom of the head. Maybe wheel studs are different, but I kinda doubt it.
Fett
766
  • Mar 9, 2007
Well Steeda says their 3" studs are actually a little longer than 3" from tip to tip, and 2.5" studs are longer as well.
Steeda claims that their 2.5" studs will fit under center caps....but not in all cases. I am putting on a set of 97 GT 17" rims, and the center cap would not fit over the 2.5" studs. So I was forced to remove them and go back to stock studs. O
J
Wheels-Tires Need Some Help - Brakes Upgrade/Wheel fitment
  • jaygee15
  • Dec 8, 2025
  • 3 4 5
4K
Fox 5.0 Mustang Tech Oct 6, 2026
jaygee15
J
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
A
SN95 Multifunction Madness! Need some big brain assistance from you folks
  • Awnaw
  • Oct 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 10, 2026
AeroCoupe
D
Will 2023 (Non-Handling Pack) Mach 1 Wheels Fit A 2013 Mustang GT OK?
  • dmw_4814
  • Oct 27, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Oct 27, 2026
dmw_4814
D
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
