rack and pinnion
  • Thread starter Thread starter kubelvag
  • Start date Start date Jan 2, 2005
K
kubelvag
15
  • Jan 2, 2005
Ok from what I have read on here my 67 coupe did not come stock with power rack and pinnion. Now the hard part how due I identify it so I can rebuild it. It is leaking like no other (a quart a week) it is a rear loader(mounted behind the center point of the front wheels) I'll try to post a pic tommorrow just want to fix this really bad. as the stang is now my daily driver while I restore my VW.
I was in love with mustangs before I could drive and had to settle with a Bronco (hey it still has that blue oval up front) Then I got a wierd itch to buy a beetle and have been stuck on mustangs and bugs ever since and plus the bug gets 29mpg and still has a crap load of power out of a 2.1 liter stroker
reenmachine
20+ Year Stangneter
Jun 27, 2004
1,258
Montrose, CA
Jan 2, 2005
  • Jan 2, 2005
Yes, for sure your car did not come stock with rack and pinion steering. Post a pic or two. Are you sure it needs a rebuild? There are lots of ways to leak that don't require a rebuild. Clean all of the fluid off, run it around the block, and see where the leak is coming from.
G
GerryB
Hamilton New Zealand
Jan 3, 2005
  • Jan 3, 2005
Hi kubelvag,
This may not be a quick fix but is probably your best solution long term.
A great steering and suspension upgrade for our early Fords.
www.rrs-online.com/html/steering.htm
Cheers.
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
Help with window and possible engine
  • StefRena22
  • Jun 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2025
Willybill32
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
J
Fox body - godzilla, coyote, or 408w stroker - Best route for budget build?
  • jaygee15
  • Jan 27, 2025
4K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 30, 2025
2000xp8
