  • 2005 - 2009 Specific Tech
Radiator Flush ---a few quick questions
  • Thread starter Thread starter chgovfk
  • Start date Start date Dec 7, 2011
chgovfk
531
28
59
AZ
Dec 7, 2011
  • Dec 7, 2011
I have an 07' GT w/22k on it - it 'sits' alot - I've read through alot of forums - so I think I know how to flush it - either buy the flush kit from prestone or pump water through it while it's running- question - never did it before -
If I flush it with water can I just use the hose w/tap H2o - and then when I'm doing the 50/50 mix just use/add the distilled water?
Also - I assume there's a drain at the base of the radiator - is this correct (forums show one for 99-04) - I have a ford manual and will look at the car but?
I'd like to clean the reservior tanks out - do I have to remove them or will they naturally turn back 'clear' with the flush?
If I leave the cap off - will this clear the air pockets out - burp the car as everyone is speaking about?
Admin Dude
Jan 4, 1985
43,545
21,715
234
Box behind Walmart
Dec 7, 2011
  • Dec 7, 2011
Yes, you can use tap water for the flush (remove as much of this as is humanly possible when the flush is over)
You should use a flush component (buy from the parts store)
You can use something like CLR if you have a lot of scale (from using tap water in your radiator)
Yes, there should be a petcock on the radiator.
Use a few gallons of distilled water for the final flush and top off with 50/50
Use tap water in your cooling system only as a last resort and flush it out at your earliest opportunity.
chgovfk
531
28
59
AZ
Dec 7, 2011
  • Dec 7, 2011
Thanks for the info Noobz347
K
Konrad
27
  • Dec 14, 2011
Beware, don't put cold water in a hot engine for obvious reasons. Also, with the coolant still cold, the thermostat won't open so it won't flush properly unless you take that out.
Admin Dude
Jan 4, 1985
43,545
21,715
234
Box behind Walmart
Dec 14, 2011
  • Dec 14, 2011
In other words: run the car to operating temp. I wouldn't remove the t-stat for just a flush.
Saying Hi
  • BriansNSane
  • Dec 20, 2025
  • The Welcome Wagon
The Welcome Wagon Dec 21, 2025
BriansNSane
M
  • mnky99
  • Sep 5, 2025
mnky99
M
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Engine Cooling reservoir questions
  • R82148V
  • Oct 3, 2022
2K
Fox 5.0 Mustang Tech Oct 16, 2022
Mustang5L5
