Radiator mods for reverse flow water pump?
  • Thread starter Thread starter 88 Fox GT
  • Start date Start date Aug 14, 2004
88 Fox GT
1,674
Iowa
Aug 14, 2004
  • Aug 14, 2004
I need to know what modifications need to be done to my stock radiator to make it work with the EFI motor. I will be using the surpentine belt setup so the water pump will be reverse-flow.
xoxbxfx
3,959
Southlake, TX
Aug 14, 2004
  • Aug 14, 2004
dont worry about it... the water flows the same direction but the pulley spins the other way
67coupestang
509
  • Aug 14, 2004
i think hes worried about the radaitor fitting being on the wrong side of the car...
option 1: get a new radiator...
option 2: Maybe you could find a shop that can modify your radiator?
option 3: some of the early bronco guys have had a metal tube bent to wrap under the crank pully and go back to the passengers side...
67coupestang
509
  • Aug 14, 2004
oh poop i guess there is a 4th option, get a passenger side dump universal rotation pump... I think most marine applications fit this bill
xoxbxfx
3,959
Southlake, TX
Aug 14, 2004
  • Aug 14, 2004
you sure you need to do all taht??? I dont think you do. My buddy has a fox that origionally had a reverse pump on it and he swapped to a standard rotation flow pump and it was fine. The fins on the impeller are just reversed to make the water flow but it still flows in the same direction.
88 Fox GT
1,674
Iowa
Aug 17, 2004
  • Aug 17, 2004
Well this site says he had a radiator shop reverse the water outlet and drain valve for about $30.
http://users.ev1.net/~gbuzek/Engine.htm
Since it's reverse flow, it will pull the water IN where it flows OUT now. So the radiator will have to be modified to make the hoses fit in the right places. Right?
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
Engine Standard or hi flow water pump?
  • AnthonyA1234
  • Sep 28, 2026
Fox 5.0 Mustang Tech Oct 9, 2026
2000xp8
water pump pulley stock diameter
  • KAWMAN2
  • Jun 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 17, 2026
General karthief
Idler pulley as substitute for Power Steering Pump ?
  • Bhenders
  • Jul 15, 2026
  • Other Auto Tech
Other Auto Tech Jul 16, 2026
LILCBRA
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
