Radiator mods for reverse flow water pump?
88 Fox GT
1,674
Iowa
I need to know what modifications need to be done to my stock radiator to make it work with the EFI motor. I will be using the surpentine belt setup so the water pump will be reverse-flow. :shrug:
i think hes worried about the radaitor fitting being on the wrong side of the car...
option 1: get a new radiator...
option 2: Maybe you could find a shop that can modify your radiator?
option 3: some of the early bronco guys have had a metal tube bent to wrap under the crank pully and go back to the passengers side...
you sure you need to do all taht??? I dont think you do. My buddy has a fox that origionally had a reverse pump on it and he swapped to a standard rotation flow pump and it was fine. The fins on the impeller are just reversed to make the water flow but it still flows in the same direction.
