  • 1994 - 1995 Specific Tech
random shutdown?!?!?!?!
  • Thread starter Thread starter chief44
  • Start date Start date Jun 14, 2008
C
chief44
50
Western PA
Jun 14, 2008
  • Jun 14, 2008
I have a 35 mile comute to work one way. When I drive in during the morning, no problem. While driving home in the afternoon as I am running down the interstate my car will die, it only lasts for a few seconds, usually by the time i realise it did it it will restart by compression. When it happens the tach goes to zero, like no power. I think it is electrical, but electrical is not my thing, any ideas????
desertcox05
379
south atlanta
Jun 14, 2008
  • Jun 14, 2008
have you pulled any codes from my experience it sounds like the dizzy is going out common prob with the sn's ck the batt cables first and make sure theyre clean and tight
C
chief44
50
Western PA
Jun 15, 2008
  • Jun 15, 2008
I am not sure what you guys are calling the "dizzy". I really need to get this fixed. This is my daily driver. I will pick one up tomorrow.
HISSIN50
34
129
Jun 15, 2008
  • Jun 15, 2008
If a car stalls while in gear for a 'few seconds', you'd know it. Do you clutch and declutch to compression start it again or are you able to do nothing and it starts running fine again?
The dizzy is the distributor and the part that fails is the PIP, aka Profile Ignition Pick-up, aka ignition stator (what it's often called at Ford or some parts stores).
Start with pulling codes - if you see a PIP or IDM code, that will be telling. There are a few other components which can cause similar issues, hence why narrowing it down is so important.
For a quick check, remove the dizzy cap and rotor, and look inside the bowl. If you see metal shavings, that's a tell (bad PIP). IF you try to move the components inside the bowl (The PIP is two piece) and they move, that's a tell for a bad PIP. A magnet can help you find shavings (because the PIP works on a magnetic field).
spock2001us
143
  • Jun 17, 2008
I had the same thing, it went on for a bit. At first I noticed it when driving. Like you wrote, my car would stall from time to time and start right back up. Then it got to where it would stall and not start for a few mins. I bought a new PIP for $20 or so but I could not get the old one off the distributor without the right tools (the stupid gear would not budge). So, I brought the PIP back to Autozone and bought the reman distributor which is about $80 which includes a new PIP. Installed, set timing, and all stall issues immediately disappeared. If you don't want to goof with the timing, make sure you carefully mark the position of the dist. cap when you remove the distributor....then line up the mark when putting things back together.
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
