rattle noise?
  • Thread starter Thread starter paintballtommy
  • Start date Start date Jun 11, 2004
P
paintballtommy
244
concord, ca
Jun 11, 2004
  • Jun 11, 2004
i have a noise that comes from what i think is the transmission/converter but near the back of the engine. it sounds like an empty rattle can almost and is really scarring me as this is a brand new 351 w i jsut put together inside my brand new freakin engine bay. could this be the tourque converter i didnt pour tranny fluid in the converter when i installed it so i dont know if that makes a difference but everything else is fine. my oil preassure is around 60-70 at idle i dont know if that is too high or what but it is a brand new motor with less than 15-20 miles on it so yeah. its a 351w with headders car has power steering but we pulled the cylinder down and noise got quieter. the tranny cooling lines are close to the oil pan but that doesnt make much of a difference it gets a little quieter when i grab them. when i rev the motor up the sound goes away at around 2-3ish and up and the motor jsut purrs and sounds great at that speed. the noise is also there when the tranny is in any gear, park, reverse, neutral, and drive. the motor does shake quite a bit at idle but the mounts are new and everything. note that it only makes this noise when the motor is at idle and shaking. anyone i am in desperate need of help. could my converter and tranny have gone south? need help.
thanks,
tommy
1969mach1351
285
Sacramento, CA
Jun 11, 2004
  • Jun 11, 2004
I just had something very similar when I changed my torque converter. The converter was not seated against the flex plate right and made a loud rattle noise. Fixed that then started it and it still made a sound but it was faint and went away when I revved it up above 2K. It was making noise because it was low on fluid and I had new cooler lines which were full of air. After going through the gears and filling the tranny all the way with fluid the noise went away. I had to run it until it got up to temp before the noise went away. Could just be the converter filling up? If it was the tranny I dont know why the power steering cylinder would have an effect. Have you driven it like this?
P
paintballtommy
244
concord, ca
Jun 12, 2004
  • Jun 12, 2004
yes i have driven it like this but only to the muffler shop bout 5 minutes away to get my exhaust welded on. when the engine rocks at idle the headers would rub and hti the power steering cylinder. i fixed that but it now sounds like a rattling from the converter or near the back of the engine/transmission.
ratio411
3,870
73
109
Pensacola FL
Jun 12, 2004
  • Jun 12, 2004
Some possible problems that rattle/knock at rear of engine:
Cracked flexplate
Loose flexplate bolt/bolts
Loose torque converter nut/nuts
Loose inspection plate
Converter not seated
Wrench left in bellhousing after rebuild...
Dave
P
paintballtommy
244
concord, ca
Jun 12, 2004
  • Jun 12, 2004
hehe ill check all that stuff
thanks guys.
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
2001 v6 New compressor issue
  • badmech
  • Apr 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 30, 2026
badmech
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
E
Noise near blower motor behind dash?
  • Ethereal_Zer0
  • Dec 31, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 3, 2026
Ethereal_Zer0
E
